Guitar (or earlier part of normal fx chain) -> H9 input 1
H9 output 1 -> amp input (or later part of fx chain that runs to amp input)
Amp FX send -> H9 input 2
H9 output 2 -> Amp fx return
Just add in the Timeline to the fx loop portion of that circuit. So it would go Amp FX send -> Timeline input -> Timeline output -> H9 input 2 -> H9 output 2 -> Amp FX return
I only ever had just the H9 in the loop and never owned a Timeline but that's the logic
Basically, use what @Timmyo has posted above, but slightly modified if you want it all in the loop:
Amp fx send -> H9 input 1
H9 output 1 -> Timeline input
Timeline Output -> H9 input 2
Then the only thing to need to be sure of is that you set up each patch to be pre or post as this defines if it uses I/O 1 or I/O 2.
My music:- https://soundcloud.com/hubobulous
The way I posted moves the H9 pre loop/in loop with the Timeline staying in the loop
I was planning to have the Tumnus and The Elements (when the switches stop banging) in the front, and Timeline & H9 Max in the loop, and use the H9's mods pre- and the reverbs (or 2nd delay) post-Timeline within the loop.
