Timeline and H9 Max: pre-post routing in amp FX loop
I'd like to set up the H9 so some effects can sit before and some after the Timeline, with both in the amp's effects loop. Can someone advise on how I connect all the cables to do this correctly? Cheers.
  • TimmyOTimmyO Frets: 7556
    Pre/post works like this:
    Guitar (or earlier part of normal fx chain) -> H9 input 1
    H9 output 1 -> amp input (or later part of fx chain that runs to amp input)
    Amp FX send -> H9 input 2
    H9 output 2 -> Amp fx return
    Just add in the Timeline to the fx loop portion of that circuit. So it would go Amp FX send -> Timeline input -> Timeline output -> H9 input 2 -> H9 output 2 -> Amp FX return
    I only ever had just the H9 in the loop and never owned a Timeline but that's the logic
    Red ones are better.
  • Basically, use what @Timmyo has posted above, but slightly modified if you want it all in the loop:
    Amp fx send -> H9 input 1
    H9 output 1 -> Timeline input
    Timeline Output -> H9 input 2
    Then the only thing to need to be sure of is that you set up each patch to be pre or post as this defines if it uses I/O 1 or I/O 2.
    Ah right yes, what @hubobulous  has posted is what (re-reading your post) that you asked for - switches H9 before and after the Timeline, but both are always in the loop.
    The way I posted moves the H9 pre loop/in loop with the Timeline staying in the loop
  • Perfect, gentlemen, thank you.
    I don't own any of this gear, but I prefer the sound of the above routing, that way you can get all your drives and modulation in front of the amp, where they belong.
    I was planning to have the Tumnus and The Elements (when the switches stop banging) in the front, and Timeline & H9 Max in the loop, and use the H9's mods pre- and the reverbs (or 2nd delay) post-Timeline within the loop.
