Good Quality, but not extortionately priced, true bypass wah recommendations?
peteripeteri Frets: 1283
Hi
Can anyone recommend a good, true bypass, wah pedal? I tried the crybaby mini and whilst I liked the sound, my big feet want a full sized pedal.
I'm not a massive wah user, but like to do the odd Jimi impression - so would like a wah, but don't want something sitting there the whole time costing a fortune or sucking signal.
Any recommendations?
Pete
  • jpttaylorjpttaylor Frets: 465
    Apparently the EHX Wailer Wah is true bypass, and it's £52 on most websites - seems to get pretty good reviews.
  • KebabkidKebabkid Frets: 3307
    I have the new-ish wah from BOSS - the PW-3.
    It's solidly-built (die-cast), sturdy and offers 2 voices, true-bypass, has lights on the side to show it's on and is about the same size as the Xotic i.e. scaled down but not as small as the mini-Dunlop.
    Sounds fine and does the job for £99
    BBE Ben Wah, very very satisfying :)
  • TeetonetalTeetonetal Frets: 7802
    I like the Ernie Ball wah. As it's discontinued bargains can be had.
  • TTBZTTBZ Frets: 2898
    Thanks for posting this, wasnt aware boss did a small decent sounding wah. Looks like it could be just right for my board :) it's not buffered like a normal boss then?
  • peteripeteri Frets: 1283
    Thanks all. Ordered the EHX too cheap not to and can always return
    I don't believe so and this one's been a little under the radar but check out the clips.  Treadle is big enough.
    That's just a cheap knock-off of the highly respected Vertex Axis Wah.
  • digitalscreamdigitalscream Frets: 26608
    edited March 2017
    They're not true-bypass, but the Weeping Demon and the Junior have a good buffer in them and don't suck the signal dry like the Crybaby.
    <space for hire>
    @digitalscream  - are you referring to the Boss? Apologies, I think you might be right but I'm sure someone in one of the demos said it was but none of the bumf says that.
    No, the Ibanez Weeping Demon.
    <space for hire>
    edited March 2017
    OK.  No perceivable tone suck on the Boss if others are wondering.
  • NickLNickL Frets: 153
    If you like the sound of the Crybaby Mini but not the size, would a standard Crybaby left switched on in the loop of a bypass loop switcher do the job, or would that require too much tap-dancing? As well as fixing the tone suck that could give you a status LED if you add power.
  • professorbenprofessorben Frets: 5105
    Love my Crybaby standard.
    I haven't noticed any tone suck tbh, I run it after a buffer tho.
    Crybaby isn't as bad as a stock vox. That thing killed my sustain.
    :) that's where I got the idea it must be good if it fooled all those pros into thinking it was handmade etc. They were right, it's great :)
