So here is a pic of a Wudtone pre-cbs style development with a few twists.
This plate has
3 visible differences to an original pre-cbs plate that Wudtone incorporate.
plus there are
2 differences underneath ( not visible) that are part of the established Wudtone design, customers rave about.
We will send a free plate as per the pic ( vintage mount, block, compatible) to the first forum member who can complete as below.
visible Wudtone feature 1 = benefit =
visible Wudtone feature 2 = benefit =
visible Wudtone feature 3 = benefit =
underside feature 1 = benefit =
underside feature 2 = benefit =
Many thanks in advance for your entry.
Visible Wudtone feature 1, the recesses to the rear of the pivot screws benefit = stops the bridge rifing up & down the screw in use
Visible Wudtone feature 2, milled string holes benefit + err stops strings binding on front edge of holes
Visible Wudtone Festure 3, It's a thicker plate than standard ? benefit = got to sound better surely ?
Underside feature 1 = Err the 'ramp' on the underside is different well it is on mine, benefit = feels smoother in operation, you dont get that 'clonk' when you use it
Underside feature 2 = the steel plate you stick on the body benefit = not using the painted top of the guitar as your pivot point of the trem it's metal to metal
How did I do teach ?
If so I really really want it !
Arrrggghhhh
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
