It's not capacitance ( too drastic anyway) and I'm buggered if I know what it is.
Ended up getting an old DSD-3 which is awwwwwwweeeesssome
There's a switch in the Flashback which turns off the true-bypass behaviour and leaves the buffer engaged at all times; a side-effect of this is that you'll get delay trails after you switch the pedal off, for smoother transitions. Read the manual
EDIT: Holy shit, did I know something that @ICBM didn't?
It could be a new ask the umpire/penn and teller fool us type feature. Ask @ICBM, where regular fret boarders attempt to trip up @ICBM with questions about obscure single production run dutch valve amps and the nested submenus of early digital rack FX.
… is the correct solution .
Always with the trails.........
