Memorising Long Pieces
olafgartenolafgarten Frets: 1648
Hi, I'm trying to learn Offend In Every Way by the White Stripes but am having trouble remembering the start as it is quite long (around 50 notes). What techniques do you use to remember things like this?
I have tried splitting it up into smaller sections but that hasn't helped much. Maybe I should just keep practising.
  • BigLicks67BigLicks67 Frets: 768
    Look at the first 4 bars of the TAB/Music and play through about 10 times, then put the Tab away and and see if you remember it. If not start again until you do. Then go through the whole piece the same way.
    Also, if it's melodic and memorable I'll try and work it out by ear first and then check it against the TAB.
  • RiftAmpsRiftAmps Frets: 3171
    edited May 2016 tFB Trader
    I always learn things backwards - by that I mean I learn the last phrase first, then the penultimate phrase, and so on.
    For example, a four phrase section would be learnt like so:
    4
    3+4
    2+3+4
    1+2+3+4
    This way, I always know what's coming next and more importantly, where to position myself ready for the next phrase.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    @RiftAmps interestng idea :)
  • fretmeisterfretmeister Frets: 24338
    4
    3+4
    2+3+4
    1+2+3+4
    I might try that.
    Usually I just play with the CD over and over again until it sinks in.
    Thanks, I've just about got it using the backwards idea. It really worked!
  • guitarfishbayguitarfishbay Frets: 7961
    Try learning to vocalise it entirely first. If you really know how the whole part goes it'll be easier to remember how to play it.
