Tape delay- I'm using this set at 350ms with a low mix for a general delay for thickening single note lines and giving some body to particular rhythm sounds. At first I didn't find it quite bright enough... But then I remembered how annoying the TC tape emulation that I used for years was because it wouldn't darken up. Just depends on what you're used to I suppose!
Elephant Man- I use this delay for anything that needs delay as an actual effect and not just an ambient effect. It's cool, I always get on with DMM's and DMM emulsions on whatever unit I'm using
Deluxe Comp- this is GREAT. I set the mix at about 80 but everything else is default. Absolute belter of a compressor. Really impressed
Throaty wah- my favourite all time wah is my own Picture Wah so it's only natural I'd like the RMC emulation. The wahs are light years ahead of the M series ones (this is the point where someone tells me they are the exact same) and after a little tweak of the envelope it sounded very sweet. Vintage and sweet. Just the way I like it
Plate Reverb- not my favourite reverb by anymeans but for creating a little space in an all purpose, not getting in the way kinda situation then this suits. I turned the high pass up a little from the default
Chorus- great at default. Well done line 6
Script Phaser- also great at default. Very good!
In stereo
Mmmmmm
It also just gives you the dry guitar on pass thru
To be fair there have been some issues on Mac with drifting word clock but I understand them to be fixed now?
