I'm with you on low action, too - I don't get "fight", I want it to be as easy to play as possible, within the bounds of actually getting a sound out of it...
My experience is that the tone potential (I say potential because it's not tone until a player's technique makes it tone) of an acoustic guitar is affected not by action per se, but by things like the height of the strings off the soundboard (ideally around half an inch right in front of the bridge), and also break angle over the saddle (minimum is that you shouldn't be able to move the strings on the saddle when tuned to pitch). Lowering the saddle of the average production guitar to super-low action measurements would likely compromise those key measurements and detract from the tone potential of the instrument. Some players won't miss it, others will.
My YouTube Channel
http://acousticguitar.com/checking-and-adjusting-saddle-height/
I bought a pre-shaped replacement bone saddle from Martin (keeping the original as is, just in case of mishap) and sanded the bottom on some 100 grit paper. It was quite time consuming and tricky to get the bottom properly flat but I got there and the action is now 6.5/64ths to 4.5/64ths and feels a lot better.
I won't go any lower as I can play quite hard bar chords around the 7th fret, Pete Townsend style and hate any hint of buzzing and this action is just high enough to prevent that.
much happier now.
