Behold my massive board of pedals
1144145147149150395
    http://i38.photobucket.com/albums/e120/timmysoft/Mobile Uploads/image_zpsrz4nbxvl.jpeg
    Theres es my pedalboard, on top of my amp! I'm doing my best to keep my rig as simple as possible so I concentrate on writing and recording!
  • LaurieLaurie Frets: 97
    edited October 2016
    Nice!
    I had pretty much the same set up for 15 years.  TS-9 on top of my old Blues DeVille amp.
    At the end of the day, good guitar playing/technique, good sense of melody, chord vocabulary, skills in working with other musicians and complimenting/enhancing the music, etc, trumps all the fancy gear in the world.
    We're recording our second album next month.
    Keep on keeping on..
    edited August 2016
    Nice!
    couldn't agree more! I will never be a great guitarist, but id like to think i'm a good writer and fun to be in a band with! The gear whoring is on its way out, i'm now just pushing to write and record better music.
    good luck on the second album, its the hardest one!
  • Lez325Lez325 Frets: 86
    edited August 2016
    Heres my home made board on top of my Fender  Blues Deluxe
    Right to Left-
     Boss SD 1 Overdrive- Mooer Phaser - Tone City(Tape Machine) Delay - MXR Dyna Comp- Boss Loop Station
    http://i.imgur.com/SogxvKa.jpg
    Les
  • BeefBeef Frets: 260
    Thought it was about time I should share.
    NPD: "Overdrive pedal distortion retro" - bought from some bloke on eBay, don't know much about it. Sounds good.
  • paul_xtpaul_xt Frets: 86
    cbellanga said:
    Updated .. using a temple board solo 18, very nice indeed!
    How you finding the temple board? Seen a lot of varying reviews on them and unsure whether to pull the trigger or not.... I really like the whole modular idea going on with it
  • cbellangacbellanga Frets: 572
    I like it a lot .. definitely an improvement from pedaltrain. I like the raised angle, helps reaching the pedals on the back, the option to have a junction box on the sides, the perforated base so I can pass the cables through them.. it's still quite light and strong and just a tiny bigger than my previous metro 16.
    I'm also thinking of moving the comp (set and forget) under the board.
  • vasselmeyervasselmeyer Frets: 3674
    edited August 2016
    Whilst Chris from @CustomPedalBoards wires up my BOSS ES-8 board, I've had to put together a secondary board with some of the pedals that won't make it onto that one. I'm quite looking forward to playing this actually, though not so much the tap-dancing.
    Effects into preamp:
    Polytune > Plutoneium Chi Wahwah > EHX Soul Preacher compressor (bleh...) > Catalin DLS MkII >
    Timmy Clone made by @handsomerik
    In the loop:
    Mooer Ninety Orange > Visual Sound H2O (wired for chorus first then delay) > MXR CC > Diamond Tremolo
    I have cut the cable off the footswitch for the amp as it was fraying badly and had it drilled so that I could wire a Neutrik locking stereo jack in. I just use a TRS cable from that into the footswitch socket on the back of the amp.
    The H2O delay gives me a short/slapback delay and the CC is set for a longer one for a dotted-eighth feel if I want it. The only one of these pedals I'm iffy about is the EHX compressor which is OK, but I'm so used to the SP compressor with its blend control now that I cant really get a sound I'm happy with. Plus it's so noisy when it's on.
  • Whilst Chris from @CustomPedalBoards wires up my BOSS ES-8 board, I've had to put together a secondary board with some of the pedals that won't make it onto that one. I'm quite looking forward to playing this actually, though not so much the tap-dancing.
    Polytune > Plutoneium Chi Wahwah > EHX Soul Preacher compressor (bleh...) > Catalin DLS MkII > @handsomerik >
    Timmy Clone
    In the loop:
    The H2O delay gives me s short/slapback delay and the CC is set for a longer one for a dotted-eighth feel if I want it. The only one of htese pedals I'm iffy about is the EHX compressor which is OK, but I'm so used to the SP compressor with its blend control now that I cant really get a sound I'm happy with. Plus it's so noisy when it's on.
    oooh that'll do it!
    hey nice early version DLS
    for all things pedal boards please visit www.custompedalboards.co.uk
    Timmy Clone
    In the loop:
    oooh that'll do it!
    I LOVE the MkII. I had a chance to upgrade it to the MkIII but I couldn't seem to get the same thump out of it when you wind the "Fullness" up on the Mk.II.
  • yeh i got the silver 1, is that the mk3 is it? nice pedal tho, i find it a better sounding M type OD than the SL drive from xotic
    The first one as white, then the MkII was purple. The MkIII is sliver and has BMT controls where the MKII has "Presence" and "fullness". They're both great MiaB pedals although I think Wampler's Plexidrives just edge them.
    There was also a limited version of the mk2 with BMT controls, I believe they called it a super bass DLS.
  • therose789therose789 Frets: 467
    edited August 2016
    edited August 2016
    Needs more metalzone
  • baddog01baddog01 Frets: 8
    edited August 2016
    Nothing special here  just some some tones that I enjoy daily :)
    https://imgur.com/a/hOj5H
  • TTBZTTBZ Frets: 2927
    edited August 2016
    I've simplified! After years of it living on my board I think the Vox wah is off for good. Not only do I use it as a crutch to make boring solos sound a bit more interesting (ala kirk hammett), but I didn't realise how much the bypass was sucking my tone and sustain. Like, really noticeable amounts. I think it's amplified with my SG as it doesn't have as much natural sustain as the LPs I've always used, but taking it out of the chain makes such a difference. It's meant to be TB modded but not sure how well that's worked. Think I may downsize to a PT nano+ (just to allow for a few extra pedals, have a DD7 which may go back on) and get a onespot.
  • LoobsLoobs Frets: 3846
    edited August 2016
    Something like this - I should put it on a board though. Dragging this shit to gigs is annoying.
    Fuzz sometimes swapped out for a different one. Echo Park sometimes swapped out for TC Flashback.
    I only use the Echo Park for reverse echo, it sounds so good. The Ibanez Delay Cheap was a gift, does fine for warm-sounding quicker delays. I've had one for about 10 years.
