Bandcamp
Bandcamp
The front back and headstock were done with copies of comics from tinternet, copod and pasted in miniature on the pc, and all filled an A4 paper size collage, printed on clear waterslide paper, a couple of thin coats of lacquer to seal the water based ink, applied to the guitar and sealed in place with. ore lacquer, applying 2 A4 size waterslide transfers was fun!
It worked very well and was a bit of fun!
You could scan and print your football cards and apply then individually or as a collage......
http://i260.photobucket.com/albums/ii21/paulnb57/image_zpsd7703b71.jpg
stickers like that tend to have a fair layer of adhesive which will never sit great under lacquer. You might get away with it more if the adhesive is thin and hard
waterslides work much better under lacquer
Instagram
Bandcamp
