I'm looking to re-wire my strat to have Volume - Neck and Mid, Volume - Bridge and Master Tone, keeping the 5 way switch.
However, I'd also like a push-pull option on the first volume, to bring in the bridge pickup to join either neck or neck and mid.
Would I basically just need to follow this -
http://www.tdpri.com/threads/strat-wiring-mod-2-volumes-1-tone.299591/...And then use a push/pull pot instead for the first vol pot, take a wire from the bridge port of the selector switch direct to the push/pull section of the pot?
Thanks
I'd like to go for the same 2 volume, 1 tone set up (so Vol 1 - Neck and bridge, Vol 2 - Bridge, Master Tone/just neck and mid tone).
But I'd also like the 5 way switch to be Neck, Neck and bridge, bridge, bridge and mid, mid.
All the diagrams for the 2 volume set up I've seen have the bridge pickup going straight to the Vol pot, so that naturally causes some problems for changing over the selector switch option.
Doing either seems easy enough, but what can I do to do both? Is a blend or push-pull still the best option?
Thanks
Switch side 1: terminal 1 - neck pickup; terminal 2 - no connection; terminal 3 - middle pickup; rotor - to neck/middle volume top terminal.
Switch side 2: terminal 1 and terminal 3 - from neck/middle volume middle terminal; terminal 2 - bridge volume middle terminal; rotor - tone control and jack.
