One minor annoyance is the FX loop which is a pre-set 50/50 parallel loop. For me, a series loop would be better as I often use a looping pedal - I have to go into the front of the amp which means I can't use the Laney's drive channel when looping.
Nice little amps, but not the loudest 15w (in comparison my PRRI appeared quite a bit louder with a similar Jensen Speaker in)
For gigging in a rock band it would have to be the 30w for me.
Perhaps you could get more out of it if you could squeeze an Eminence Ragin Cajun or something but if it's for just home playing they are great.
Might well do the deal then!
Only issue is the main on/off led doesnt seem to work.
Other than that cracking.
Need to look out for a footswitch now.
"Nobody is really researching robot jokes"
