hahaha LOL:
If a user fails to read and follow the update instructions, Helix will cause their car radio to play only polka death metal every Thursday from 1-3pm PST
Will at least wait a few days.
I've not used the amp models, I'm just using it as a pedalboard using the 4CM. I think it sounds great. The looper is really good. Obviously, the Helix is not cheap, but then again, pedals, power supplies and pedalboards aren't either.
To make it even more entertaining, the guys in the band aren't aware of this, so I look forward to seeing if they even realise I'm not lugging in 60KGs of amp and cab.....
Tried using a cable instead of wireless, tried a different guitar, unplugged everything from the Helix besides in and out, tried it using headphones to check it's not the speaker, created a new patch with just an amp and cab, used a downloaded patch from Glenn Deluane.... still sounds awful.
Here's a video - http://sendvid.com/joiaabdm
I've already got the cab low cut quite high, the amp block is default settings, and even have the low pass filter on the K10 speaker engaged. No global EQ.
This is the second problem that's cropped up with the Helix, and I'm reliant on it for gigs (many of which are in the next few weeks for Xmas and NYE!!!). Feeling pretty deflated with it right now, TBH - just don't understand what's happened!
Turned out it was also a 6 week wait for parts but I managed to convince my retailer (Guitar Guitar) to send me a replacement instead.
Thankfully, the guys at Andertons are exchanging it for me tomorrow
Bit of a strange topic I know, but I'm getting my replacement unit today, and I'd like to know that there's no fault with it (seeing as my old unit had a couple of them).
Can anyone point me to a good 'real world' demo of how the Helix should sound when going FrFr please? Ideally nothing that's been post-produced, and is just a simple patch. Looking at a lot of YouTube vids, they're all DI'd or post-produced, which doesn't really give me the 'true' sound.
Thanks!
Some interesting sounds, I quite like.
http://line6.com/helix-native/
Helix FW 2.20 Preview (The "Get Low" Update)
AVAILABLE IN FEBRUARY—DON'T GO LOOKING FOR IT!
New Amps
- Line 6 Badonk, all new Line 6 original inspired by the original high gain Big Bottom model
- Del Sol 300, based on* the Sunn® Coliseum 300 bass amp
- Woody Blue, based on* the Acoustic® 360 bass amp
- Busy One Ch1, based on* channel 1 of the Pearce BC-1 bass preamp
- Busy One Ch2, based on* channel 2 of the Pearce BC-1 bass preamp
- Busy One Jump, based on* channel 1 and 2 (jumped) of the Pearce BC-1 bass preamp
New Hybrid Cabs
- 1x12 Match H30, based on* the Matchless® DC-30 cab (12” G12H30 speaker)
- 1x12 Match G25, based on* the Matchless® DC-30 cab (12” Greenback 25 speaker)
- 1x12 Cali IV, based on* the MESA/Boogie® Mk IV 12” cab
- 1x12 Cali EXT, based on* the MESA/Boogie® 12” extension cab (EVM12L speaker)
- 1x12 Del Sol, based on* the Sunn® Coliseum 300 bass cab (12” speaker)
- 1x18 Del Sol, based on* the Sunn® Coliseum 300 bass cab (18” speaker)
- 1x18 Woody Blue, based on* the Acoustic® 360 18” bass cab
New Effects
- Dynamics > Auto Swell (Mono, Stereo), Line 6 Original
- Distortion > Obsidian 7000 (Mono, Stereo), based on* the Darkglass Electronics® Microtubes B7K Ultra bass preamp/overdrive/EQ
- Distortion > Clawthorn Drive (Mono, Stereo), based on* the Wounded Paw Battering Ram bass overdrive
- Delay > Vintage Swell (Mono, Stereo), Line 6 Original
- Delay > Adriatic Swell (Mono, Stereo), Line 6 Original
- Pitch/Synth > 4 OSC Generator (Mono, Stereo), Line 6 Original
* All product names are trademarks of their respective owners, which are in no way associated or affiliated with Line 6.
New Features
- Global Settings > MIDI/Tempo > Send MIDI Clock—Helix can now transmit MIDI clock to synchronize the tempo of external pedals, rack gear, and software. Select “Off” (Helix does not transmit clock), “MIDI” (Helix transmits clock from only the MIDI OUT jack), “USB” (Helix transmits clock only via USB), or “MIDI+USB” (Helix transmits clock from both MIDI and USB)
- Global Settings > MIDI/Tempo > Receive MIDI Clock—Helix can now synchronize its time-based effects (such as delay and modulation) to incoming MIDI clock from external DAW software, drum machines, keyboard workstations, or other modelers. Select “Off” (Helix ignores MIDI clock), “MIDI” (Helix responds to clock received at its MIDI IN jack), “USB” (Helix responds to clock received via USB), or “Auto” (Helix uses its internal tempo generator until receiving clock from either MIDI or USB)
- Variax Workbench HD Support—Variax can now communicate directly with Variax Workbench HD software (Mac/PC) through Helix via USB.
- Clear Bypass Assignment—Individual blocks’ bypass assignments can now be cleared. From the Bypass Assign screen, select the block whose bypass assignment(s) you wish to clear. Press ACTION and then Knob 1 (Clear Assignments).
- Line 6 Allure Pack IRs—Dan Boul of 65 Amps has created a pack of six user impulseresponses for use with Helix or any other modeler or software that supports them. Download the free Allure Pack here:http://line6.com/allure/
Improvements/Changes
- Receive MIDI Clock and Send MIDI Clock have also been added to the Tempo panel shortcut.At any time, touch TAP to open the Tempo panel.
- Reverb > Plate, Room, Chamber, Hall, Echo, Tile, Cave, Ducking, and Octo have all been optimized to be less DSP-intensive
- Pitch > Pitch Wham, Twin Harmony, Simple Pitch, Dual Pitch, and 3 OSC Synth have all been optimized to be less DSP-intensive
- Additions to and improvements made to the existing factory preset bundle
- If a user fails to read and follow the update instructions, Helix will scare small woodland creatures back into their holes, triggering sixmore weeks of winter weather
