Recording with a THR10
Have tried a little recording with the above stuff, but whilst something appears to have been recorded. It does not play back.
I have checked the drivers but computer flashes up a message about a soundcard not supporting anything.
So which soundcards a I likely to need.
OS is Windows 7 32bit.
Thanks in advance. R
  • ecc83ecc83 Frets: 1636
    How are you getting a signal into the computer?
    To make any really decent recordings you need an Audio Interface.
    Dave.
  • rolls1392rolls1392 Frets: 235
    Dave.
    Hi Dave
    Am using the supplied usb wire between the amp and pc.
    Does the THR10 not work as an interface or do I need some additional hardware?
    Help I'mlost!!
    Thanks
    R
  • furtherfurther Frets: 88
    You might need the Yamaha Stienberger USB driver
    edited January 2014
    Don't seem to be able to post a link but go to Yamaha support and its there
    Thanks for the info.
    However, after blundering about a bit and using the THR as a soundcard/driver thing(I have no idea what I'm talking about) it works!!!
    Don't know how or why but it does.
    So for now thank you
    Roland
