You can buy one commercially, or use any normal attenuator as one if it's set to the quietest setting - although that's usually an expensive option. You can build one fairly easily and cheaply if you're handy with simple electronics. The advantage compared to an attenuator is that they can be much cheaper, and they arguably affect the sound of the amp less since it's not in line between the amp and speaker. Or you can just use a normal attenuator, they don't affect the tone much either when only set to a fairly small reduction.
Changing EL34s to 6V6s is simple, the bias voltage is in the correct range so all you need to do is accurately rebias it using the normal trimmer, and set the amp to half the impedance of the cab in order to compensate for the different valve impedance. The tone will also be slightly different, a bit softer and 'rounder', but in a 1987x that's probably no bad thing.
Have you seen or tried the Victory Sheriff 44? I wonder if that is a viable option or maybe even a Silver Jubilee?
I'm not quite sure what the problem is with the two Marshalls - if the JTM45 is too mushy and not loud enough the 1987x will probably be perfect. If the 1987x is too loud and brash, the JTM45 will probably be perfect.
Attenuators are simple and give you control on a non-MV amp. A parallel dummy load is even simpler.
The Jubilee I wondered about just because isn't it a version of the 1987 or was that when it was built? I get lost in all the models to be honest.
The JTM45 is still sounding like the amp for me. If it is loud enough for pubs and clubs yet still having enough headroom for effects. I don't mind a little bit of mushy as I'm used to using an 18watt tweed.
I actually think the SLP is a bit redundant. If that's the sound you like, the 1987 would be ideal. The JTM doesn't sound too alike to the bigger EL34 powered amps.
If it's more the aggressive kerrang and upper mid bite you like, go 50w small box. If you want something a little warmer, and possibly more polite, go for the JTM.
The 1987 will need an attenuator. There's no way you're getting that into overdrive at anything like audience friendly levels. But don't let that put you off.
Both amps sound great. I've had both a few times. They are also very very cool.
The reissues are also well put together.
I'd go 1987x and possibly a Fryette Power Station.
if you find a JTM45 to mushy bring it to me and I ill tighten it up in 10 minutes (allowing time for the iron to heat up and the coffee to be made)
I have been lusting after a rockcrusher attenuator, one of the more expensive options to drop volume but works really well, I have a number of clients that gig with JTM45 in pubs in regularly, just don't get a cab with vintage 30 speakers!
cab wise I have been having a quick look at zilla's and I'm guessing Greenback/creamback is the way forward with either amp.
I definitely would if you get a 1987.
Technically a pair of Greens would be ok, but it'd be much safer to run Creams IMO. I'd not want to crank a 1987 through a pair of Greenbacks. They'd probably be ok, but I wouldn't bet a great deal on it, as I think the 1987 is capable of putting out more than it's rated wattage, and Greens are rated at 25W a piece.
A JTM would be cool through Greenbacks. In fact the 1962 (basically a JTM 45 combo (?)) has a pair of Greenbacks in it from the factory. (I believe, could be wrong.)
I think the whole idea of the Creamback was to be a high powered Greenback, so tonally they're similar. The classic Marshall sound usually involves Greenbacks, so can't really go wrong. If anything, the Creamback with its higher power handling is more versatile. Mainly because of just that. For example a pair of Creambacks would be ok with a 100W amp. I'd be very nervous running my JCM 800 up through a pair of Greens!
Thinking outside the box a bit, try a few old cheap Brit valve amps such as Selmer (TnB 50), WEM Dominator, IMPACT, Miles Platting etc. Before the amp bods jump on me, no I'm not suggesting these are JTM45s et al but they are great oldie amps from a similar era.
You might find one of those might suit you more. Most take pedals and are still cheap albeit the days of them being 50 quid/ worthless are probably over unless you get lucky.
From what I know of you and your playing, a well sorted simple classic valve amp is what you are after and those above might offer a surprise once you plug in.
Just a thought.
Cheers
Hugh
www.proudhoney.com
I have tried a few amps out that didn't work for me, such as the Two Rock Exo, Fender Super sonic 60 and even the MJW standard roadster. They were all great amps but they didn't quite fit in with the band. I'm being a little unkind to the MJW there as it did but I have the EL84 thing covered with the Tweed version.
As as you know I'm a classic rock type of player but I do use a few pedals such as delays, Trem and phaser along with a dose of Fuzz face which is why i am thinking that an amp with a little more headroom than my 18watt might work now that the studio time is finished and it's months of gigging instead.
Theres something about growing up idolising pictures or Eric and Jimi leaning on Marshalls that does make me want to have one too.
A second hand JTM is a good shout as you'll not lose if you but wisely and sell on if it's not your thing.
Time to get off here and get out demoing/ finding some vintage or inspired by vintage tone machines
Cheers
Hugh
www.proudhoney.com
