Vox foot switches?
robgilmorobgilmo Frets: 3494
I believe I need a VFS2 for my Cambridge reverb amp, so what is a VFS2A foot switch?
  • susbemolsusbemol Frets: 403
    edited December 2016
    The same two button footswitch but with LEDs. They are not always interchangeable though so check your manual.
  • VoxmanVoxman Frets: 4724
    A Marshall 2 button switch will likely work fine too.
  • gubblegubble Frets: 1746
    This reminds me of when I purchased a 2 button marshall footswitch for a Marshall VS100 probably 16 years ago.
    The shop in Bradford (now long since gone) had one in that instead of saying Channel - OD1/OD2 said something like Channel - Reverb.
    The guy was adamant it wouldn't work and was not happy selling me it. In the end I had to promise him I'd buy it and not bring it back under any circumstances.
    Sure enough the footswitch worked. I even discovered that the 2nd footswitch was labelled with a sticker, removing said sticker it said OD1/OD2 underneath.
    It tickled me that did.
  • ICBMICBM Frets: 72410
    If it's a standard latching footswitch for an amp which can take one, any plain footswitch will work.
    Where it gets more complicated is if the footswitch has LEDs - then sometimes the LEDs won't light, the footswitch won't work or the LEDs could blow, or a combination of those... so it can be risky to try unless you know.
