A phaser question...
HAL9000HAL9000 Frets: 9697
Currently thinking of buying myself a phaser pedal to get that subtle slightly swirly sound.
I'd prefer something with just one knob and just a mono out.
Probably overthinking things here but...
A quick Google search suggests that phasers often have model numbers which include  45, 90, or 100. I guess this is something to do with the degree of phasing going on - would that be correct? And do I need to concern myself with such things?
Also, I see that there seems to be 2-stage and 4-stage phasing. Again, anything I need to worry about?
From what I've managed to find so far, I'm liking the look of the DoD Phasor 201 and the MXR Phase 90. Ok, I know I need to go and try them out, but is there anything else I should be looking at?
Thanks.
  • SporkySporky Frets: 28483
    You are correctish about the numbers. Phasers work by shifting the phase differently at different frequencies, so it's not really an exact thing.
    The number of stages relates a bit to the number and to the maximum phase shift.
    The Phase90 is a bit of a classic; I believe it's a 4-stage. I think it's probably the sound you're thinking of. I also really like the Boss PH-3 for the "rise" mode.
  • OctafishOctafish Frets: 1937
    As Sporky says phase 90 is a 4 stage and phase 45 is 2 stage. I believe the phase 100 is a phase 90 with an extra knob? I
    I'd also check out the new Phase 95. It's a mini pedal and has switch for both phase 45 or 90 style phasing and a switch to change between older more subtle phasing and newer more full on phasing.
  • I have the phase 95 and its great. But the Mooer Orange Ninety is simple and great too
  • ICBMICBM Frets: 72484
    No, not at all - it's a completely different circuit, much higher-quality - almost to studio equipment level - but it doesn't have the same swirly sound of the Phase 90.
    Apart from the requirement for one knob, I would [stuck record] recommend the Boss PH-1R. Old, discontinued, but not too rare - and it can nail the sound of the Phase 90 as well as being far more versatile. Possibly the best standard-size pedal phaser ever made. [/stuck record]
  • If you want subtle its the phase 45 or Dod, the 90 is more in the Van Halen camp of flanging.
  • LebarqueLebarque Frets: 3884
    Don't dismiss a Small Stone type. Great phase
  • Dod 201 is amazing, it's only 1 control but the slow rate is nice and subtle, great for atmosphere and the faster rate is very good for that faux leslie type thing. It's been on my board since they relaunched it.
  • I'm a big fan of the small stone personally
  • monquixotemonquixote Frets: 17648
    I've got a 95 incoming.
    Looks like the ultimate phaser.
  • simonksimonk Frets: 1467
    Delighted with mine :)
  • Dave_McDave_Mc Frets: 2360
    Would be interested to hear what you think of it when you get it. :)
    I will share my findings.
    I've had an orange 90 before which I liked but I fancied the 45 mode on the 95.
    Thanks. Same here, I've got the script w/LED phase 90 and the extra couple of settings in a smaller footprint might be nice if it sounds good.
  • If you're tempted by MXR Phase types then you owe it to yourself to at least try the 74 reissue Phase 90, beautiful sounding thing.
  • mike_lmike_l Frets: 5700
    The script phase 90 is a thing of beauty.
    That or the EVH phase 90 would be my first choice, and in a close 3rd, would be the block logo Phase 90.
  • Careful with the script thing, there are at least 2 very similar looking script Phase 90s,  both MXR Custom Shop.
    One has an LED and power socket (same circuit as the script button on the EVH) and the other is the 74 reissue, no LED or power socket.
  • GassageGassage Frets: 30929
    Anyone knows that phasers have two settings- Stun and Kill.
    moogerfooger 103 phaser does
    / insert gratuitous pic of a young William Shatner as Kirk
  • RandallFlaggRandallFlagg Frets: 13946
    edited December 2016
    Phase 90: Sex Pistols - Anarchy In The UK
    Phase 100 - The Clash - Jimmy Jazz (or other London Calling tracks) and Rolling Stones - Beast of Burden (sounds good on the live version on the B-Side to Going to a Go Go single 1982)
