yo, some basic wisdom (but wisdom nonetheless) required. I like my jaguar very much, and have performed the 'series-parallel' mod on it. Which is great but there is far too much low end when engaged.
"The fool" they all cry, "there's a switch on the jaguar that takes away bass!" But it takes away all the bass reducing the tone to similar proportions to the standard pickup options. What would I do to the 'strangle switch' so that it cuts a bit of that low end but not as extremely as the current stock circuit?? Different cap? A resistor? Thanks!!
A larger cap has larger layers, basically - which means that it can store more charge and hence pass lower frequencies more easily than a smaller one.
Does that make sense?
