Strat trem arm tip too loose - easy remedy?
My partscaster has a new, longer trem arm but none of the 3 tips I've gathered over the years fits - all too loose. How can I remedy this without buying another? Is using silver foil around the arm a sensible fix? Or glue of some sort...
  • PTFE tape around the thread of the arm does the trick
  • scarry67scarry67 Frets: 143
    Ah, the plumbers' tape. I've got some somewhere. Thanks...
  • ICBMICBM Frets: 72419
    Paper masking tape will work better probably - PTFE tape is very thin.
    Failing that, Araldite :). It's not exactly something you'd want to take off again… often they're moulded on anyway.
  • ToneControlToneControl Frets: 11928
    yep,  wrap the right way round  so that it doesn't  screwing it in, and quite tightly too
    buy it from B&Q or amazon
    The tape worked well - bloody thing doesn't stay in tune mind, but it looks nice
  • tone1tone1 Frets: 5169
    Yep +1 for araldite  :)
