12 string Euro style JM build
13»
    WezV said:
    Like this
    like the idea of that
    Weather it's worth doing or not is anyone's guess
    I'd do just 12 and 6 string though
    With this you can do the bottom bit as a 6 string and then make both a Bass and 12 string top, then switch them out.
  • WezVWezV Frets: 16778
    The real question is whether you would bother switching it all around once the build was finished.  Unless you could quickly change between songs you probably wouldn't.
  • DanielsguitarsDanielsguitars Frets: 3301
    Once you build the damn thing,  not to mention the cost of getting it done, then find out I wish I hadn't bothered
    Other builds to do before I worry about that anyway
    On with the build wez, i'm starting to really like jazzmaster shape guitars
    www.danielsguitars.co.uk
    (formerly customkits)
  • impmannimpmann Frets: 12677
    WezV said:
    Like this
    Actually... (Shergold Anorak alert)...
    That guitar had several 'halves'. There were two 12 string halves (one top and one bottom layout). There was a four string bass, and a six string bass. There was a regular Shergold 6 string half and a later half made by Roger Giffin with a Strat neck and three pickups.
    It was also a 'modulator' which meant that the electronics control plates could be replaced by undoing the silver screw and then pulling them out. There were several different electronics modules - some were simple, some less so involving active electronics.
    It was totally designed in conjunction with Mike R and was actually his idea, as playing his parts in Genesis were so complicated it was necessary - for example some songs needed 12 strings with alternative tunings ('octave' strings tuned to fifths etc). It also had a balanced output - the connector on the bottom was a four or five pin "XLR" type for many years, although I believe this was simplified in later years.
    Sadly Mike hasn't played it recently - even for the recent Genesis tour despite returning to the old material. As a result, I didn't think it sounded so good... the Shergold has its own sound.
    A good friend of mine built a full replica of this guitar - with all the different 'halves' and because he wanted it authentic, and most of the parts are bespoke, he had to make a lot of it from scratch. For example the pickups and pickup rings are an unusual size/shape and were only ever used on Shergolds and some Hayman guitars - he found a method of making them himself. Likewise he researched and developed the special connectors to enable the separation etc.
    Aside from Scott's amazing replica guitar there was only ever *one* demountable Shergold. Apparently the costs of manufacture would have been prohibitive. Some of the 'halves' have been sold off by Mike R but the majority is still stored at "The Farm", Genesis' studio. Scott has also built a few twin necks for the Genesis tribute bands, including (IIRC) the left-handed one.
    There is more info on this guitar (including some pics taken fairly recently) on the Shergold website - www.shergold.co.uk
    I knew it had a 6 string neck too, but as always you are a mine of info for all things shergold :)
  • PhilKingPhilKing Frets: 1486
    I originally had 2 songs in the set in mind for the double neck.  They wouldn't have been at the same point though - you need some time to recover after using it.   The mando 12 matches a John Birch style SG that Wez made for me.  I have it tuned to B, for Hotel California.
    Jim Rodford had a Precision/Strat double neck that used to separate in the Argent days - but I can't find any pictures of it.
    i finally found the old jap trem bridge for this, which saved me buying something at more than i would willingly pay for a full guitar.  The only issue is it was missing its arm and springs, but new versions are now available on ebay so i got one of those.
    The seller offered to relic it, but the original bits are still quite shiny, just a bit scratched up from spending 15 years in a drawer of random parts.  Instead i have put it in a bag of screws and shook it around a bit
    it took some slight modding to fit the new arm, but it feels a lot more stable than the vintage examples, spring seems decent and the pivot point is so simple I am sure i could improve it if needed
    Anyway, cost me very little so I am going to give it a go :)
    Awesome
    edited January 2017
    went single ply binding in the end but i am very happy with it.  I might need to dull down the shine of the perspex a bit though, i will probably hand buff it at some point to soften it
  • Looking good Wez, I like the scratchplate design. What do the switches do, on/off?
    yeah, it will just be on/off for each with a master volume and tone
    I still need to decide what i am doing with the 6 non-trem strings... probably through the body, but i am goign to test it all out as a 6 string like this first as the trem may not stay
    the back has been heavily rounded over too
  • I thought the back looked rounded over. Nice attention to detail. I'm really interested to see how the half term works it's a really interesting idea.
  • valevale Frets: 1052
    that is lush. & a trem for the high six set will be amazing. or evil horrible. fun anyway.
    where did you find the template for the body shape? it looks bang on.
    hofner hussie & hayman harpie. what she said...
    I printed one off I found online and stuck it to some MDF.  That was a few years back when I made my first jazz master.
    i have done similar by scaling up full frontal pictures.  Either way it's very important to check a few known dimensions - scale length, pickup size etc
    thanks for the tip WezV. just noticed your SG Vox Mando thing at the top (pic must have not loaded first time i checked the thread). great body shape (Hagstromy) & finish. true skills!
