So what do you guys think of my Little Wing cover?
selfobsessednewguyselfobsessednewguy Frets: 18
edited January 2017 in Making Music
I'm really insecure about my Little Wing covers and would like some criticism before I perform this live. This is my cover of Little Wing
edit: Ver 2:
  • boogiemanboogieman Frets: 12382
    Sorry but your timing is way off. Maybe practise over a backing track to get it better. The actual playing and phrasing is ok though.
  • AlnicoAlnico Frets: 4616
    Don't take that on stage.
    You can play, there's no doubt and the sound, although i thought it had a little too much gain for that song, was fine.
    What's not right is as @boogieman says the timing is off but also the structure of the song seems to lose itself.
    Try going back to it and writing the song out on A4.
    Structure it in on paper and remember what that image looks like, you will then see that on stage and remember the songs structure by that image.
    If you go back and break the song into chunks, learning each one individually and then recognising where each section effectively stitches together it will help drastically.
    Also listen out for contact points.
    If you've never heard or heard of these, they're licks or phrases that are recognised by the band to signal the end of a section or even the song itself. There is a VERY obvious one played by DG, ascending the neck in whole tone bends at the end of the long second solo in Comfortably Numb. It actually signals the last few bars of the song.
    You might find this and other songs you try to learn work better when you know their structure inside out.
    I do something i call 'Immersion' whereby i listen to a song i'm trying to learn on repeat on headphones for a couple of hours, again and again. When i pick the guitar up i know what's coming next every time (Most times !).
    That might help too.
    You can play and you can definitely play THAT song, it just needs some finesse and confidence but it's a really gutsy attempt at a song that's not as easy as it might first appear.
    Well done.
    If you want any direct help, PM me anytime and i'll help all i can.
    Learning by ear and playing covers live, especially at jams is what i did for many years and would still be doing now if my health would allow.
    If you think i can help, just ask i'd be glad to.
  • richardhomerrichardhomer Frets: 24810
    edited January 2017
    Don't want to be negative - but as the others have said, the timing is a real issue. The 'greats' usually take liberties with timing in the sense that they effortlessly subtly shift their phrases around the basic rhythm of the song - but you can still count through it.
    You should practice along to some kind of backing track, a metronome or a drum machine. I've recently bought a Boss RC-3 looper, which has a limited range of decent drum patterns built in, which makes it a really good practice tool.
    Once you've nailed your timing you'll be all set - everything else is good.
    Hope you take this as intended - trying to be helpful/honest....
  • selfobsessednewguyselfobsessednewguy Frets: 18
    edited January 2017
    Thank you guys very much, my equipment is awful so the tone definitely has too much gain (using a £200 guitar with a £15 amp and my phone's microphone) and I won't be taking this on stage for another 2 months yet, so that's why I'm looking for help now. I didn't use a background metronome or track which is regretful actually (I just thought I could get a feel for the BPM but clearly that didn't work), I will do it again and upload it here tomorrow. Thankyou all again, do not apologize, any cnc is greatly apprectiated
  • All the phrasing is there, but just needs a slight bit of work on the timing.
    Just try playing the chords of the intro first to get the timings, e.g moving from the G to the E etc. Slowly bring in the key phrases he uses, then add your own touches. Also, don't worry about needing gain to give definition. Clean and some reverb will do it, and play different parts with different levels of force to accent it.
  • ChalkyChalky Frets: 6811
    My timing is crap. The main skill you need in playing live is timing.  Any musician with good timing, not just guitarists, will find it much easier to get gigs.  Some people are naturally blessed with it but if like me you aren't then you have to learn it the hard way with a metronome.
  • GassageGassage Frets: 30927
    I think it'll fly.
    edited January 2017
    Yeah I've heard this before, it interests me and makes a lot of sense. Does anyone use the convention of performing with a metronome in one ear (in-ear bud)?
    EDIT: Also thankyou @Alnico again for the ideas, especially the one about writing the structure down. This will help me massively x
    edited January 2017
    No problem
  • 57Deluxe57Deluxe Frets: 7339
    edited January 2017
    ...more like a wing nuts cover...
    <Vintage BOSS Upgrades>
  • blueskunkblueskunk Frets: 2877
    57Deluxe said:
    ...more like a Wing Nuts Cover...
    Nice and helpful...
  • To @boogieman, @Alnico, @5redlights  and everyone else thankyou for your help, I have redone the cover with the added help of a backing track and I have added some reverb and thought about structure more. Here is an updated version, please let me know if there is anything which sucks that stands out which I can change:
    So much better and really, *really* good expressive playing.
    Fucking really well done i really enjoyed listening to that.
    Take *That* one on stage and you'll shine.
    Keep practicing it every day like that and keep that inside-out knowledge of every aspect of it, like it sounds like you've got right now.
    If i was listening to that in a pub i'd have a massive smile on my face.
    edited January 2017
    Wow, thanks man, awesome, I'm glad you enjoyed listening to it. I will try to find a way to bring a backing track on stage then.
    edited January 2017
    Try HERE for more tracks.
    On stage through a PA shouldn't be difficult from most devices.
    Wow. 100% better, well done. I wouldn't have thought it the was the same person playing. Very nice soloing and phrasing and the timing is just soooo much better.
    I only have one more suggestion: keep the tone cleaner at the beginning and then wind the wick up when you go into the solo so you get a bit more light and shade. Otherwise, a very nice job.  :)
  • @selfobsessednewguy ; I didn't hear the first one, but the recent one posted was cool. With a decent backing track, or better yet an actual band, that would be fucking great as a live thing.
    Less gain on the intro though, just back off the volume on your guitar so you can whack it up as it gets going.
    p.s. Welcome to the forum :)
    littlegreenman < My tunes here...
  • MossMoss Frets: 2409
    That second one is genuinely brilliant
    Great phrasing, love the vibrato in particular
    Stop crying, start buying
  • GulliverGulliver Frets: 850
    Some really nice phrasing and great note choices - not just sticking to Em pentatonic like a lot of people!!
  • Col_DeckerCol_Decker Frets: 2188
    I didn't comment on the first version as what I would have said was already covered. The second version however is excellent, great work mate. Really really good.
    Ed Conway & The Unlawful Men - Alt Prog Folk: The FaceBook and The SoundCloud
     'Rope Or A Ladder', 'Don't Sing Love Songs', and 'Poke The Frog'  albums available now - see FaceBook page for details
