Callaham Bridge for my Tele
hey guys,
just looking for a wee bit advice regarding these bridges - read a lot of good things so thinking about upgrading.
There's two listed that as far as I can tell, the only difference is the LOOK of the saddles, but no difference funtionally:
http://www.charlesguitars.co.uk/manufacturers/callaham-guitars/callaham-tele-parts/callaham-vintage-tele-bridge-slant-compensated-brass-saddles
http://www.charlesguitars.co.uk/manufacturers/callaham-guitars/callaham-tele-parts/callaham-vintage-tele-bridge-enhanced-vintage-compensated-brass
Also, they look like they have extra screw holes compared to my standard bridge:
http://i86.photobucket.com/albums/k100/keir_smith/95DE04E8-DA70-40B9-A590-ED9396366986.jpg
Is all of what I'm thinking right enough? I'm guessing there will be some Tele's that have these extra screw fittings?
Cheers
Keir
  • JohnnysevenJohnnyseven Frets: 908
    edited January 2017
    The saddles are both compensated, one by having the saddle at an angle and the other with compensated 'teeth' on the saddle - not sure what the benefit of one over the other is or what the benefit of having 2 extra screws at the front of the bridge is. Just wondering why they're so pricey though?
    My trading feedback can be seen here - http://www.thefretboard.co.uk/discussion/58242/
  • koss59koss59 Frets: 849
    I might be after a Fender one like on yours. If you upgrade and want to sell then let me know :)
    Facebook.com/nashvillesounduk/
  • BrizeBrize Frets: 5630
    The angled saddles look more traditional but the intonation is more accurate on the 'enhanced' saddles.
  • The two extra screws hold the plate firm(er) against the body. A few manufacturers do this - Barden for another.
    Not sure it makes any difference myself, but others may have more knowledge/experience. Only had a Callaham plate on mine for a month or so.
  • Strat54Strat54 Frets: 2397
    Just replacing the Callaham comp slant saddles on mine after 12 years, wouldn't buy them again as I hoped they'd last longer. Alas due to the heavy slant the string eventually cuts into the soft brass and makes a tiny ridge which then causes a sitar sounding effect. Have gone for the Rutters straight compensated variety instead this time.
  • Had one on my tele since 2007 when it was new.  Never had a problem TBH.
    You've not noticed the same issue as @Strat54?
    i had considered just buying new saddles, but heard this whole bridge is meant to be good
