SOLD: TRACE ELLIOT SUPER TRAMP TWIN - superb guitar amplifier combo - made in UK - £50
RevMattRevMatt Frets: 837
edited January 2017 in Amps £
SOLD This is an epic amplifier from the excellent Trace Elliott company. They introduced these amps back in the 90s, having already built their reputation as a leading bass amp maker.
The Super Tramp Twin is one of the bigger amps in the range featuring an 80 watt power amp, two channels, high quality reverb unit and a 2x12 combo format - please note, there are currently no speakers fitted or included with this amp, however, I do have a separate speaker cab so it can be seen and heard working. I am also happy to fit speakers for you if you supply them.
Tonally, this amp is phenomenal - the clean channel gives great clarity with a very natural warmth (attributed in part to the Mosfet amplifier). The drive channel has 2 switchable gain stages (low or high) and is further controlled by it own eq and gain controls. There's also a master control section for reverb, presence and master volume - the latter makes this amp very usable at quieter volumes, although crank it up and it will shake the foundations! The driven sounds are excellent, offering great versatility covering low driven bluesy tones all the way through to higher gain metal sounds.
The amp is in excellent condition considering its now around 20 years old - it's fully working and just needs a pair of speakers dropping in to turn it back into a gigging monster.
