So....
Will anything do this?
It needs to be invented, now.
And Saturnworks seem to do one.
These are both based in the States.
I'm trying to figure out if Bright Onion over here do something that could be used as one.
[edit] It's 4114Effects
But building anything like this is way beyond me.
EDIT -- I'll email Bright Onion next week.
Cheers!
Good spot, I missed that one.
I've now gone from thinking they don't exist to having to choose between a pretty one and totally functional one that's a bit cheaper!
I'm trying decide if I need it or not (I am an accomplished tap dancer)... but I suspect it's one of those things I'll find a use for if I have it!
http://www.brightonion.co.uk/looper-with-amp-channel-selector/
DAMN I was close!!!
http://www.thefretboard.co.uk/discussion/93755/fs-wobo-inverter-effects-looper-routing-switcher-pedal-40#latest
@Grunfeld Happy to do you a deal if it suits your needs.
@Bowks yes the wobo does exactly what I was originally wanting but I'm now going for the dual loop AND reverse function too -- I can see me using this.
As it happens closer inspection of Bright Onion shows they do two reverser pedals, the "simple" one which @Sporky linked to and a version with dual loops Dual Reverse Looper.
But many thanks for letting me know about yours and good luck with the sale. (cheers @benmurray85 for the heads up too).
