KLD 15w hand-wired amp head - odd control query
VoxmanVoxman Frets: 4725
edited January 2017 in Amps
Planning to have a look at this today.  Bit odd as controls are at the rear, not front or top.  Its 15w, with Pentode Triode options.
But intriguingly it has two additional knobs - one labelled 'Sky' the other 'Earth'.  Anyone have any ideas as to what these do?
  • VoxmanVoxman Frets: 4725
    OK, found it - Sky is a Treble Boost Gain, Earth is a Bass Boost gain...interesting.
  • saw that on ebay, its in barnet looks interestng but i dont need another amp
    edited January 2017
    Just checked it out, very nice guy (Tony) selling it (like me, a  'mature' player!) who I've actually met before as his band used to rehearse at the same place as us.  Had a nice chat & he showed me a couple of his Les Pauls too.
    It's a nice little amp, in very good condition, and it was quiet with no hiss/splutter. I played it through a 4x10 cab but I found it wasn't perhaps quite as loud* as I was expecting it to be - tubes are all good (re-tubed around a year or so ago I'm told). Reasonable amount of clean headroom with quite a nice warm & very usable tone, and a respectable gain/crunch tone - but nothing that 'grabbed' me.  Unlike newer versions, no built in reverb or FX loop (as can be seen from pics).  The rear mounted control panel is a little awkward, & I had to turn the head around to tweak them.  I'm sure it was designed with the player standing behind the amp/cab in mind, ala certain Vox and Fender amp controls eg AC30, Bassman etc (but although reversed, at least those controls are on top).
    I wasn't looking for another amp but went to see it because it was local, I liked that it was hand-wired, and I thought it might be nice to have a little amp head that give me something different tonally.  In truth, I don't think it does and I felt that my 15w Laney Cub 12R with Celestion Vintage 30, reverb & fx loop is a bit more versatile, louder (Re volume of the 15w head, I'm probably a little 'spoilt' because the V30 in my Cub is 100dB, which is probably making it the equivalent of a 25-30w amp with a 97/98dB speaker), has a tone that suits me a little better (it has been re-tubed with JJ Hand-tested tubes that really make a big difference to clarity and a bell-like top end), and has a little more clean headroom.
    But if anyone is looking for a nice 15w head, that's hand-wired, is quite compact & light, with useful features such as pentode, triode & variable power-modes, I think you could certainly do a lot worse especially with a £75 start price.  And the seller is very nice, and I'm sure would be a stand-up guy to deal with.
  • ChalkyChalky Frets: 6811
    Got a link to the Ad, @Voxman ?
  • i bet it sells nearer £200
  • jpfampsjpfamps Frets: 2734
    Not sure how you "hand test" a tube............
    put your hand on it when its been on a while and if it burns your skin off its HOT :)
