i keep my G1on at work for lunchtime jamming : works great with headphones and has drum machine, 30sec looper and an aux in.
It's also pretty sturdy. I'd have no worries about using it live if I had to.
I have the G5 and found that any Headphones with a decent low end and mid range will work well, make sure you change the mode to Combo Front though, or it will sound shrill.
In terms of volume I have the expression pedal set to control the level of the Spring Reverb at the end of the chain, every pedal has a level control between 0 and 150 so you can use that. Although you won't have the expression pedal on the G3 but turning the dial isn't too much work.
I think there is also a global level control aswell.
