Either use it on its own wall wart (I don't recall if they come with one in the box?) or isolate it using a GigRig Timelord (I don't think a single output from a Gigrig Isolator has enough current, hence the Timelord)
I got the impression the isolator was just an add-on to the actual PSU, so will supply whatever current the PSU you're using puts out. If the Volto has the juice I wouldn't expect it to be a problem.
Or am I missing something?
FWIW, Diago also make a ground isolator adaptor they reckon is compatible with the El Cap.
http://www.diago.co.uk/adaptors/isolator.html
