Recommend me a delay pedal
markjmarkj Frets: 914
edited January 2017 in FX
Looking for a quality delay pedal new or secondhand for £80 to £100. Any advice welcome.
  • If you want a basic-ish but reliable tap tempo delay pedal, the Akai Headrush E2 is good.
    I'd suggest looking at a Line 6 M5 though. It'll 'be' a normal delay unit if that's all you want, but there's loads more to experiment with too.
  • markjmarkj Frets: 914
    edited January 2017
    I'm just looking for quite a basic delay. What about tc electronic flashback or digitech obscura? Please keep coming with suggestions.
    DD-3, no need for the early long chip ones, basic and brilliant.
    It you need tap tempo then Boss DD-7 or 20.
    Boss do the basics really well :)
    Boss DD-3 innit
    Or, for small footprint, I recently added a Valeton Moon Echo to my life.  Really nice (other than the brightest LED on the planet but a bit of gaffa tape managed to dim it to acceptable levels)
  • TTBZTTBZ Frets: 2902
    Hard to go wrong with a DD7, you get a lot in it for not much money. Tap tempo without an extra switch is a ball ache though.
  • Digitech Hardwire DL-8
    Good point on the DL8 :)
    Because a DL8 and say a DD-3 sound different.
    You might want to try some, find what works for you.
    Boss for me personally, the DL8 works great but it made the sound thin, for me personally.
  • FuengiFuengi Frets: 2850
    edited January 2017
    TC Alter Ego and the Digitech Obscura both on my board and get plenty of use, would recommend without hesitation. The TC is hard to get a bad sound out of, the Obscura has more warbly modulation which doesn't necessarily sound like what you are after.
    Also have a Memory Toy but don't use it much, I actually prefer the TC's MM settings.
    Also look at the Boss DD7, Echo Park or Carbon Copy.
  • shadyshady Frets: 252
    Another vote for the DD-3 if basic is what yer after.  I have one alongside a Boss RE-20 Space Echo which is also brilliant.
  • TRex Reptile (not the Replica) has a great sound and is easy to drive. They come in at that sort of price second hand. I love mine over the TC Alter Ego X4 I also own (and should sell).
  • TeetonetalTeetonetal Frets: 7807
    Mooer ana echo for super simple. 2nd hand nova repeater for some good options.
  • Def the Boss DD-3.
  • valevale Frets: 1052
    edited January 2017
    i swear by digitech delays for delay&verb. analog a far murkier & more subjective world. maybe suggest what you want to play & ppl can suggest an analog delay to fiit.
    hofner hussie & hayman harpie. what she said...
  • SassafrasSassafras Frets: 30294
    I'm quite happy with my Hardwire DL-8.
    You should be able to find one 2nd hand within budget.
  • BowksBowks Frets: 414
    Another vote for the Hardware DL-8 here.
    Basic delay for £100, yep, I can do that.
  • DesVegasDesVegas Frets: 4557
    The Behringer echo machine has it all if you can get it past the cork sniffers. I also have the alter ego and that is indeed fab
  • thomasw88thomasw88 Frets: 2328
    Save up and get a dd500.. once you go there you'll know it's worth it
  • hubobuloushubobulous Frets: 2352
    edited January 2017
    Line6 Echo Park or for real simplicity, Mooer Ana Echo
  • GassageGassage Frets: 30928
    Spent £120 last week on Chiltern Railways and got two delays.
    Great value.
