My JV '62 RI Precision has a noisy volume pot that isn't responding to switch cleaner/lube, so replacement is in order.
I have some of the 'vintage-style' CTS 250k's with the dished cases, but the old Squier P-bass knobs won't fit on, even with the split shafts squashed a bit.
Which ones do I need?
If you don't want to buy more pots, make sure the set-screw can't crush the split shaft - it's already weakened by bending it, be *very* careful when you open it out again. Cut a piece of thick pick to fit the slot and stop it being pushed inwards.
