Are you using it in valve or solid-state rectifier mode?
Amps are a bloody nightmare - I don't think i have ever owned an amp that didn't cause me problems. Very very seriously considering buying one of the new generation solid state amps.
Probably half my repair work is solid-state amps. It's not always serious faults, but anything that stops your amp working properly at a gig is a serious enough fault really - you're going to need some sort of backup if you're relying on it to get through the gig, unless you've got some means of going through the PA.
AKA 'you can't win' .
