Lower wattage amps with good cleans . It's been asked a 1,000 times
  • @Voxman , sounds great with the Les Paul!
  • VoxmanVoxman Frets: 4726
    edited January 2017
    As I said its a cracking little amp - the Strat demo had the volume way down at under 2 on the cleans and because the videocam was at the other end of the room, it didn't pick it up quite so well - I'd forgotten that single coils aren't as loud as H/B and that I needed to up the volume.  But remember too, my Cub isn't stock and you could always put a higher headroom speaker in.  The new ones come with an HH speaker which are pretty decent whereas the Rocket 50 mine came with was rubbish, hence the V30 upgrade.
  • ESBlondeESBlonde Frets: 3594
    I'd default to the Princeton too given what you ask for. There are a few modern remakes by the booteek fellas too if that is your thing. Used Princetons go about £750+ and rising due to the £/$. If price is the limiting factor a used hot rod deluxe for about £300 gets you 90% there with 40w and slightly heavier overall package.It will cover any gig and go down for home use.
  • Creed_ClicksCreed_Clicks Frets: 1389
    edited January 2017
    I'm in € land, so will check on £/$/€ . A hot rod deluxe. I'm familiar with them, so might look into one again. But again, I wouldn't use the overdrive channel at all... or else would use channel 2.
    If I could get the hot rod deluxe as a 20 or 30 watt, I'd be happy. Good workhorse of an amp too. Will look into the suggestions above...
  • Are you not just making your life difficult? Surely deciding on the wattage of an amp is the least effective way to pick one?
    try a load of amps, see which sounds best to you, then consider the output volume.
  • Well, I suppose I wouldn't get a 10 watt amp, it just wouldn't cut it for most gigs.
  • OP, it's a brainer, the 65 fender deluxe reverb reissue is the amp you are looking for but do bear in mind it has no fx loop.
    edited January 2017
    I don't mind (no effects loop). I never used one before, always went straight in. Need to raise the $$$ :)
  • They are a proper tone machine and worth the asking price. Good luck
  • Look at the Laney LH50 - it's a smaller size head with 50 watts of a really sweet clean channel and a pretty usable classic rock crunch channel.
  • CorvusCorvus Frets: 2929
    edited January 2017 tFB Trader
    I like my Blues Deluxe at home on 2, just got a vol pot attenuator to try as well. Mine's switchable to 6L6/6V6 about 22-25 watts but it's not loads quieter for it, and makes no odds at house levels. I don't use the drive channel although it does a certain thing well when hit hard with a boost.
    I have seen a battered but functional HRD go for 200 squid... decent cleans for £notalot.
    I'm not bothered about the vol on two thing, if it sounds good then it's good. And I can gig with it no worries. Not too heavy either, it's not much more than my lad's Blues Jnr.
  • Saw a hot rod for real cheap today. I do like the blues junior but probably won't get clean cleans out of it! I had a junior before. Decent amp for the money.
    Sorry, but the blues junior is one of the worst sounding and most overpriced amps I've ever played.
  • Corvus said:
    I like my Blues Deluxe at home on 2, just got a vol pot attenuator to try as well. Mine's switchable to 6L6 about 22-25 watts but it's not loads quieter for it, and makes no odds at house levels. I don't use the drive channel although it does a certain thing well when hit hard with a boost.
    How is the vol pot attenuator in the loop working out for you, are you still getting a sweet top end or getting a duvet in front of the speaker type sound ?
    It's literally just been unwrapped but will post back later or tomorrow after giving it a run.
    Which one did you buy ? I'm really interested to know how you get on as I returned a hrd III as the clean channel volume was ridiculous.
  • ToneControlToneControl Frets: 11947
    how clean?
    proper clean against drums needs 100w
    indie clean 30w
  • Indie clean !
    Overpriced yeah but I found it ok. Saying that , I have no experience of really high end amps
    This one - http://www.ebay.co.uk/itm/141620893968
    Cheap enough not to bother making one.
    So after a very quick run through the BDRI - tone is kept perfectly well, if anything the top end might be very slightly more present. On clean I could get the vol up to 7 and still be at a normal house level, could go more. The response of the amp to playing is that bit nicer, bit more alive, but not a major change. It's just starting to get hairy edge-of-breakup with these low-output pickups I was using (Filtertrons).
    The dirt channel on this amp I can only get to around 3 on the master with the Drive at max and a booster pushing it for crunch. Sounds good though. Previously to get the drive channel working it was impossibly loud for the house.
    Overall - works fine for house playing at least in this quick go.
