I would try to lift it by first lowering the neck pickup as far as you can - you can do that from the back of the body - so you can get something under it where it won't chew up the finish. If that doesn't work, protect the body with some masking tape and lift it with a fairly strong blade like the larger one on a Swiss Army knife.
