Reverse polarity on GigRig adapters (need "C+ to C-" but it's the other way around)
Jonathanthomas83Jonathanthomas83 Frets: 3471
edited January 2017 in FX
So I have an Electroman, which will give me 24v with a center positive. I'll also be buying an El Paso for 15v center positive.
I need to convert that to center negative.
All I can find is center negative to center positive converters, has anyone ever found a converter cable that does center positive to center negative? If so, send over a link, please. Thank you!
