BBand undersaddle pickup - Pickup or EQ problem
Hi can anyone please advise me  .
I bought a Tanglwood Electro acoustic bass locally , all looked well until I got it home . When plugged into an amp all that comes throught is a hissing / static sound with only the faintest of the actual bass tone coming through  .
I have checked all the connections and all looks well - it is an undersaddle pickup with the  BBand EQ with the built in tuner  .
The controls on the EQ controls seem to work as they do adjust the volume of the hissing sound , the onboard tuner lights up but is unable to pickup a clear tone from the pickup for it to work  .
I have found a replacement pickup but it is £50 which may not solve the problem if it is the EQ .
Any help would be much appreciated
  • ICBMICBM Frets: 72349
    My experience with these is that it's usually - although unfortunately not always - the pickup strip itself.
    I won't bore you with my usual stuck-record rants about electro-acoustics, but suffice to say I'm not a fan of this system.
  • SteveRobinsonSteveRobinson Frets: 7031
    I think that the B-Band is one of the better sounding USTs but they do seem to have a higher failure rate and new transducers are about £50 each  :o
    That's a bit damning with faint praise though :).
  • Thanks for taking the time out to reply, I guess it's a new pickup then.
  • With @ICBM on this one BBands are definitely not my favourites try Headway
    www.maltingsaudio.co.uk
  • BigMonkaBigMonka Frets: 1771
    Just checking that you've definitely tried a new battery in it before you rush of spending!
