Just for clarity - not where it starts to do something when turned up from zero, but the point where it has the most effect over the smallest turn. I really don't know why either!
If you're worried about how it looks just set them so they sound good, remove the knobs, and replace so they all point to 12:00...
Yeah, I understand what it means but I don't see it working.
I can't test on the ac15 as it's a 6 way switch and a cut knob.
It might make an amp sound good, but would it sound best? If not, it's not really even a useful start point.
I used to work with everything maxed, then turn things down until it sounded good. That would vary depending on where I was playing.
However, I think you should judge your tone on how it sounds, not how it " looks". Between your fingers and what you or the audience hears are a whole host of variables that affect your tone. Your amp's tone controls are just part of that list of variables - set 'em where they sound good.
