FREE VSTs
  • Great thread.  Going to check some of these out tonight,
  • I very much like Melda's flanger and phaser. Both are whooshy and trippy.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • MossMoss Frets: 2409
    Also loving the Teufelsberg
    OBXD is a great Oberheim emulator
    Lokomotiv is good for a basic synth sounds
    Tunefish does some decent FM sounds, and is much easier than most to program
    Stop crying, start buying
  • I downloaded the Teufelsberg, because, if nothing else, the vibe sits nicely with the kind of electronic stuff I tinker with. Sadly, It doesn't work with Logic 9/Snow Leopard. Bugger.
    I said maybe.....
  • A few modulation VST's and an EQ and gain thingy from BlueCat, all free!
    http://www.bluecataudio.com/Products/Bundle_FreewarePack/
    littlegreenman < My tunes here...
  • HootsmonHootsmon Frets: 16018
    I have the 64 bit version of REAPER on my PC and never got round tae doing anything with it.......is there any good free 64 bit VSTs out there for reaper?
    tae be or not tae be
  • GrunfeldGrunfeld Frets: 4054
    edited February 2017
    hootsmon said:
    ...any good free 64 bit VSTs out there for reaper?
    Reaper 64 will be able to use any 64 bit VST, and indeed any 32 bit VST as well.  Even in the same project.
    All you have to do is tell Reaper where to look for the VST.
    And it's usually a good idea to avoid installing multiple versions of the VST, eg. the 32 bit, the 64 bit, and the VST3 version all installed together will just confuse the hell out of it.  Just pick the version you're going to use and don't bother installing the others.
  • stratman3142stratman3142 Frets: 2216
    The GVST effect are quite good (link below).
    http://www.gvst.co.uk/downloads.htm
    It's not a competition.
  • HeartfeltdawnHeartfeltdawn Frets: 22408
    Fretwired said:
    https://www.meldaproduction.com/MFreeEffectsBundle
    And it is worth paying for the full version. Usually 50% off in the sales.
    Tonecarver for experimental stuff. TCStretch is fabulous.
    https://tonecarver.wordpress.com/
    SQ8L - the best Ensoniq ESQ-1 synth out there.
    ArcDev and Interruptor delays
    Azurite for chorus.
    @Heartfeltdawn - I'll check those out - not come across them before.
    Melda's plugs do have a fairly complex GUI but there's so much you can do with them. The vibrato is my favourite using the step sequencer to throw in some unusual shapes.
    Totally forgot to mention Blip2000. Use it like the Tenori-On for tons of fun.
    And! Longsound.
    http://www.longsound.de/html/en_vstfx.html
    I use the Microverb plugin a lot. The GuitarFX plug is also rather useful. Sadly this isn't available now.
  • FezFez Frets: 538
    +1 for melda
    Don't touch that dial.
  • CirrusCirrus Frets: 8495
    Whoa, longsound did a DBX160? I use the waves one all the time. Any experience?
    Melda do a loudness meter that does LUFS, which is nice.
  • SnapSnap Frets: 6266
    Grunfeld said:
    Snap said:
    ...if you like that hyper pumped saturating thing,
    That hyper pumped saturating thing is my second-most disliked effect/ technique ever!  (Robot Auto Tune for the win.)
    Instant "next track" response from me when listening to new music on Spotify or YouTube.
    TAL chorus is my favourite free chorus.  Pretty much my most used VST chorus full stop.
    It depends on the track IMO. I've used it on Addictive Drums to give them a very hard edge, where they are on the brink of breaking up, sort of thing. It is easy to over do it though, in the pursuit of impact/volume. I agree though, too much pumping can make for uncomfortable listening.
    As an overall "glue" though, its a very good limiter. Very easy to use too.
    Thought this was impressive enough to revive the list
    http://oblivionsoundlab.com/product/osl-chorus/
  • FretwiredFretwired Frets: 24602
    @Moss .. niiice .. don't mind if I do .. good find.
  • IMC1980IMC1980 Frets: 146
    A1 Stereo control is great on the master bus with the safe bass control engaged and set to around 65hz:
    http://www.alexhilton.net/A1AUDIO/index.php/a1stereocontrol
    TDR Kotelnikov is also tasty:
    http://www.tokyodawn.net/tdr-kotelnikov/
    As is their Slick EQ:
    http://www.tokyodawn.net/tdr-vos-slickeq/
    I use Loudmax 64 over all the other limiters I have:
    http://loudmax.blogspot.co.uk/2016/12/loudmax-plugin-v116-released.html?m=1
  • lasermonkeylasermonkey Frets: 1940
    I've been using the Loud,ax recently and found it to work very well. Simple and effective.
    i downloaded the OSL Chorus earlier, fingers crossed it will work in my ageing setup!
    I said maybe.....
    Free EQ in exchange for an email address .. gets good reviews
    http://www.onlinemasteringstudio.eu/2017/03/13/eu-promixeq-10a-free-download/
