Hi all,
I'm looking for some help/recommendations on keeping unfinished necks in decent working order, especially feel.
I have both a Musicman JP and Charvel So Cal that are suffering with very dry/rough feeling necks.
During the restringing process I always clean and treat the fretboards using either Ernie Ball Wonder Wipes or Dunlop fingerboard treatment.
I also clean the rear of the neck with Oil Soap and treat with tru-oil and wax as per ernie balls site.
This does the job at first but after a little while, then feels horrible. The rear of the neck and also the fingerboard at times can feel rough, dry and generally not great. Is this just a trait of raw/unfinished necks? Am I just used to painted/satin necks too much?
Any help would be appreciated as I feel I'm sometimes neglecting these guitars due to the playability.
Cheers
Vince
The back of the neck is my biggest issue, feeling rough and dry.
Musicman suggest the tru-oil(http://www.amazon.co.uk/gp/aw/d/B002G1NYZY/ref=mp_s_a_1_1?qid=1390165793&sr=8-1&pi=AC_SX110_SY165) and wax to treat the back of the neck, maybe I'm not using enough? Maybe it needs further coats?
Light oil finishes like danish oil will feel rough after a time if not properly maintained. Tru-oil is not a light oil finish and should last longer, but roughness can still reappear after a time especially if you have more acidic sweat. danish tended to need re-working once or twice in the first year, but less so after that.
tru-oil and wax should work great for you so i wonder if the technique is slightly off.
Simplest fix:
1) rub back with dry 0000 liberon wire wool till smooth.
2) Apply a coat or two of tru-oil and let dry
3) rub back with wire wool and wax - keep going really working it in.
4) buff with soft cloth
Less simple, more mess - but less ongoing maintenance:
1) take the neck off
2) wetsand all wood areas with tru-oil and 800 grit+ wet and dry until a sludge forms.
3) buff off the sludge with a soft cloth - it will feel super sleek
4) repeat step 2 & 3 with higher grit
5) apply wax with 0000 liberon wire wool, really work it in
6) buff off with a soft cloth
This is generally quite hardwearing and feels great
The good news is that the more you do now, the less it should need it moving forward as a permenant patina will develop on the neck
Instagram
Still feels smooth.
I think Ball owners worry too much.
Just play the thing........
find
