Volume Pedal Rant.
GassageGassage Frets: 30928
Why can no-one make a volume pedal that works?
The latest POS to be tried and discared is the Lehle. Utter garbage.
Why can't anyone make a decent one?
  • SporkySporky Frets: 28435
    What specifically do you require of such an item?
  • VoxmanVoxman Frets: 4725
    I have an old Carlsbro passive volume pedal - still works smoothly and flawlessly.
  • ICBMICBM Frets: 72446
    Boss FV-500.
    So good Vertex removed the Boss labelling, claimed it removed any tone suck and sold it for an inflated price, and American gear-heads bought it… and the pedal.
  • dindudedindude Frets: 8538
    Never properly understood the use for them if I'm honest, certainly not enough to justify them robbing more signal.
    Its the lettuce of the fx world.
  • How did you manage to break a Lehle? It's a tank.
  • Put it after a buffer, I think Cornish makes one of those?  :s
  • BBBluesBBBlues Frets: 635
    I like the one installed on my guitar. Works great, but hard to use with a foot.
  • I hate the lack of resistance on the treadle, no matter how tight you screw it. The sweep isn't that wide either. Never noticed tone suck though and its a well executed idea to be fair.
  • Why don't you like ot @Gassage ? Rubbish rant without reasons! ;-)
  • sweepysweepy Frets: 4187
    The Boss FV500 is an awesome volume pedal
  • What does DG use, just buy that ;-)
    Have you put it on your pedalboard that sits atop your rack? If so I think I know where you're going wrong!
  • I find Dunlop DVP1 fine, it's huge but that also makes it easy to use. I've never tried it without a buffer first though.
    Because I can't strum while doing a volume swell with my finger.
    Also because using your volume knob is a pain with a noise gate. A volume pedal after a noise gate means the gate always sees the same signal so can be left on permanently. I get my gritty low gain sounds by backing off volume so this is much more practical for me
    primarily for slow fading in and out whilst playing parts, which would be impossible with a volume knob, on anything other than a strat maybe.
    that's my use anyway.
    edited February 2017
    I use a volume pedal quite a lot and find it an invaluable tool.
    I use one of the expression pedals on my Tonelab SE as a volume control to go from rhythm volume to lead solo volume on patches where I simply want a volume boost with no change to gain levels.
    On other patches, I'll set it to control gain level in a similar way to the guitar volume knob but with the advantage of no tonal drop off.  I realise the latter is strictly using it as an expression control, but some free standing volume pedals can do that too, so seemed a reasonable comparison.
    And like certain volume pedals I can set the range between toe down and heel down, or leave it as full sweep if I want.
    With my conventional pedal board I use a simple passive Carlsboro volume pedal. This is full sweep only with no parameter control.
    With my Valvetronix AD120VTX, I have a dedicated volume pedal on my VC12 floor controller. This allows setting to one of three sweep characteristics - not as controllable as the Tonelab, but still useful options.
  • Shobud- over and out
  • Tapestry Bloomery is the one I like so far - you tried that?
  • vizviz Frets: 10700
    I played for years with a Little Alligator in the loop. It was perfect. Now I just have a Keeley Katana Boost because it's smaller and I don't need the sweep. But try a Little Alligator.
  • GassageGassage Frets: 30928
    The Lehle: I think, in fairness, it's faulty. There's a huge vol boost coming in and out. Just annoying.
