Shin ei fy-2 here
Winny_PoohWinny_Pooh Frets: 7779
A friend sent this over to check out and keep if I like. Tried it briefly and sounds cool (very like the Kills or Raveonettes, mid heavy squawk) but not sure if I should use it or sell. Only thing is that the footswitch is intermittent in the on mode and I'm not sure if I should get an exact replacement or if a modern true bypass switch will devalue it?
Opinions?
@timhulio
http://i.imgur.com/KAateec.jpg
http://i.imgur.com/dDRNwDy.jpg
  • timhuliotimhulio Frets: 1286
    I like these lots! These are only slightly above unity volume, so I like to add a small booster at the end of the circuit when making clones etc.
    Take note, the battery drains if you keep a jack in the output, not the input like most other pedals.
    They're already true bypass, but use a dpdt stomper because there's no LED. This switch is a direct replacement and is far better quality than the ol' blue 3PDT switches you usually see.
    https://www.rapidonline.com/taiwan-alpha-sf12011f-0202-20r-l-011-dpdt-latching-action-foot-switch-78-0744
    I've got a Kimbara branded one of these here. It also has a dicky switch, oddly enough. I'll have a look at some point and see if it's easy to disassemble/clean.
  • valevale Frets: 1052
    edited February 2017
    sell it. some collector-obsessive will give you molto lolly for the original sticker & fancy box.
    fredric effects (that's tim right?) does decent modestly-priced copies which will sound easily as good if not even better because old caps die young. fresh caps will add a dimension.
    a basic booster circuit (lpb1) is a useful & common mod on these as they can be quiet. tim may add that as standard.
    or buy a pcb from fuzzdog & make your own. it's a tiny circuit. a couple of transistors only.
    i am seriously shit at electrics but i made a fuzzdog one & it works great.
    hofner hussie & hayman harpie. what she said...
  • Winny_PoohWinny_Pooh Frets: 7779
    Cheers Tim, I might try and open mine up too, then again I've wasted ages in the past trying to fix things that were best off replaced haha.
    Your own clone looks excellent.
    @vale I don't have any other bits and the switch is knackered and quite used so not sure how much it would fetch. Will probably A-B with my fulltone fuzz and see... then again I want a belle epoch so...
    Thanks! The one in the pic is actually an FY-2 and FY-6 Superfuzz in the FY-2 type enclosure. I do just the FY-2 in a standard size/shape box.
  • ICBMICBM Frets: 72490
    You can fix it using the existing switch.
    Disconnect the wires, rotate the switch through 180º and re-connect as it is now, except that instead of the straight link across the bottom, connect two wires (not touching each other) in a 'X' between the lower four terminals.
    Essentially what you will have done is moved the problem to the bypass, but then fixed it by paralleling the switch poles.
    Clever!
  • @ICBM will try that, sounds clever cheers
  • I've got a little boost circuit built in to mine as suggested by timhulio. It's not a everyday fuzz but I love it. I'd say keep it but make sure any mods are reversable.
  • Ben8010Ben8010 Frets: 150
    Am I right in thinking this is the one that the EQD terminal is based on?
  • Update: I took @ICBM s advice and his fix worked perfectly! Mucked around with some noisy Black Keys riffs, fun
