imo though I'd rather have a pedal that does one or two really great sounds than loads of ok sounds.
The Bogner La Grange sounds pretty good in the demos
The fact that you can boost both the volume and gain with a single footswitch is what brought me to it, but the options available are incredible. Into a Fender Twin-alike, it's basically all the good bits from a Bogner Ecstasy.
Not cheap, but definitely versatile.
A good sound for you (and your guitar amp combination) is what you might look for, in a live setting you will only please yourself and upset everyone else if you keep fiddling all night. Get a good drive sound, if you need another drive sound get a BOSS SD1 or similar for variety and combinations. Set and forget.
