Shielding a P90-loaded Gibson?
After discovering that the source of all ills with my 'noisy' instruments and amps is actually the house I live in (long story, posted elsewhere with no conclusion!), I've today found that my Gibson Midtown (loaded with humbucker-sized Bareknuckle Mississippi Queen P90s) is pretty much silent at one specific angle.  This made me wonder whether some shielding might help tame the noise and, if so, the best steps to take.
Copper taping the cavities?
Trading feedback info here
My band, Red For Dissent
  • XsmnmyXsmnmy Frets: 124
    The idea would be to enclose the whole pot cavity, with no gaps and foil on the back of the cover too, so the whole lot is insulated. Could be quite awkward but should work. You could use conductive paint also.
  • Are all foils pretty much as good or are there brands to look out for? And what about the pickup cavities?
    Out of interest, I took the guitar outside and over the road with my Blackstar Fly and there's definitely one distinct angle where the interference clears up. Lots of overhead powerlines :(
  • merlinmerlin Frets: 6695
    Making a Faraday cage around all the electrics requires a bit of work but really helps.
    I used conductive paint on my Gordon Smith with P90s. I took off all the electrics and applied three coats of shielding paint, including all the wiring routes. I allowed each coat to dry for 24 hours, just to be sure and it really helped. I don't think you're ever going to make a P90 totally hum-free, but the pickups I have installed are Fralins and after the painting, the improvement was amazing. It's now totally manageable.
    I'm not sure how one would do it on a semi-hollow but I'm sure it's doable. Check out youtube for tips.
  • equalsqlequalsql Frets: 6140
    My 79 LP Pro Deluxe has p90s and all the electronics are contained in a metal tin whose shape matches that of the cavity. It must work as I not noticed any major issues with noise when playing it.
  • ICBMICBM Frets: 72448
    edited February 2017
    No. That's electromagnetic noise - shielding only stops electrostatic noise. Single coils will always pick that up unless you enclose the whole pickup in a ferromagnetic casing - which would stop the pickup working. (There is a very specific non-ferrous magnetic shielding alloy called 'mu-metal' too, but that would have the same effect.)
    The clue is that it goes away at a specific orientation. If it's universal no matter how you orient the guitar, it's electrostatic noise or ground loop hum, in which case shielding and/or star grounding will help.
    The solution to electromagnetic noise is humbuckers...
  • Ah! @ICBM That's fine. I can live with it. I don't really understand it but can now read up on it! My humbuckers are all fine, so that's reassuring.
  • Jack_Jack_ Frets: 3175
    Copper shield all the walls in your house, turn it into a faraday cottage.
  • Trading feedback info here
    The real problem is when you have to play a gig with a single-coil guitar and the stage is so electromagnetically noisy that the only way to not have an overpowering hum/buzz is to stand and hold the guitar very still at a specific - usually awkward, and stupid-looking - angle to the stage.
    That's why any guitar I intend to gig with has at least RWRP single coils, if not full humbuckers - so at worst, the two-pickup sound is hum cancelling. Just occasionally you need it, even if it's not necessarily the sound you would want to use.
  • NelsonPNelsonP Frets: 3400
    I have a tele deluxe with humbuckers and it makes a lot of noise until you touch the strings, or bridge. Then it's quieter.
    Would shielding help with that?
    Yes. If I remember rightly those are a bit of a rat's nest inside, and in particular the wiring from the jack to the switch is not shielded at all! If so, simply replacing that with a proper shielded cable will probably make a big difference. If that doesn't do enough, you'll need to fully shield the control cavity and switch cavity - I would use copper tape, I find it much more effective than shielding paint. Tidying up the excess wire length may help too, even of the shielded pickup cables.
    Brilliant. Thank you.
    Well not exactly brilliant, but you know what I mean.....
