Have your comp, boost in loops infront of the amp and the ES5 controlling the midi of the fx loop pedals, but have them only connected to the amp fx loop
You might also need a midi junction box (1 in 4 outs)
Would also have the option of adding more pedals to the es 5 at a later date.
As an example, if you had a 2290 in there, it won't resend the MIDI CC so you need to split out.
PM me if you need some ideas.
I did this (or similar).
Had a decibel 11 switch Dr on the floor with 2 ODs and a Mobius in the loops. Single cable into front on amp. Timeline in the FX loop of amp. With the switch Dr midi controlling Mobius and timelline patches
what midi pedals are you thinking? you could always get some sort of midi loop pedal (d11 loop expander, rjm effects gizmo) to have anything switchable too.
1 long midi cable from ES5 to the mid through, and 3 short ones to the pedals on the board.
Boss implemented the midi on the ES 5 really well and the pedals you have should pose no problems.
All pedals in the FX loop would be MIDI enabled, yes.
So with the ES5
You can have some pedals in loops in the front of the amp, and others in the effects loop;
I'd need a MIDI junction box to connect all MIDI pedals to the MIDI ports of the ES5?
Ah, just saw this after I posted. Got it.
The strymons midi thru works perfectly well, so does the H9 I believe?
Im not sure about the empress though as you need a control box for midi from memory
As you are controlling the loop pedals with midi, you do not need them in the ES5 at all - unless you want to make use of Parallel mixing and order swapping - in which case go for an ES8 as it has a dedicated insert point.
ES5 is great id you want 5 loops upfront then the pedals in the FX loop not routed through the switcher at all - just controlled by it. If I was building my board again, this is exactly what I'd do.
ES5 with Soul food - Wah - DOD 201 - Boss Fz2 - an other
FX loop DD500 - Big Sky / Space controlled by ES5 midi
I've been seriously considering it for a while now.
http://www.kentonuk.com/products/select/midi-utilsel.shtml
Would hope with an ES5 to fit it on something smaller - dd500 and Bigsky would then sit on the amp.
Trouble is by the time I've gone to that amount of effort I might as well have sold the lot and bought a helix or FX8 anyway.
It does sound like a very good idea, though with the 2 Strymons and H9 all connected to the midi ports, that would leave 5 loops but I only have 2 other pedals (comp and boost/OD). This will only encourage me to buy more pedals...dangerous!
On the ES5, do you designate numbered switches to scroll between presets on the MIDI pedals?
If I read your original post, it sounds like you want the pedals in to loop to actually sit on top of the amp. Again, not really a problem as long as you have a long enough midi lead to go from the ES-5/8 to the pedals. I suppose it means that you don't have a lot of cables going from your board to the amp and that you have a shorter cable run for the effects in the loop so you don't lose any treble, but it seems a little fiddly to me. A four-core cable snake will do the job.
For reference, here's the way I have my ES-8 board configured:
Guitar >
Smoothound wireless >
Wah >
Xotic SP Compressor (loop 1) >
BOSS PS-5 (loop 2) >
TC Spark Boost (loop 3) >
Marshall Guv'nor (loop 4) >
Magnetic Effects White Atom (loop 5) >
Xotic EP Booster (loop 6) >
Strymon Mobius (loop 7) >
Source Audio Nemesis (loop 8)
I use a Custom pedal Boards patch bay and 4CM and the ES-8 can put the effects loop wherever it wants in that chain. I use the ES-8 to switch the amp channel when I need it. As well as being in the loops, the Mobius and Nemesis are linked to the ES-8 via midi so I can set up a patch to send the appropriate PC# to change preset. One additional pedal is an expression pedal linked into the ES-8 which cant is linked to the PS-5 via a TRS CTRL link for pitch shifting/whammy effects. The ES-8 can also translate the analogue expression signal into midi CC# so, for example, I can speed up or slow down the Mobius rotary effect or increase the delay feedback on the Nemesis.
Essentially, if you have something like the ES-5 or ES-8 or the Gigrig G2, you have pretty much complete control over your rig. Obviously it's cheaper to go for a Helix or an AX-8 or FX-8, but the flexibility is there if you already have the pedals and just need a switcher.
http://i1111.photobucket.com/albums/h471/gibby12345/My Images/Screen Shot 2017-03-02 at 14.30.17_zpsunghjity.png
