Line 6 Helix
1201202204206207426
  • John_AJohn_A Frets: 3775
    edited March 2017
    The Matrix is supposed to be 'flat' but everyone's idea of flat is different and it would very much depend on what cabs you are using.  The global EQ section of the Helix is great for tweaking the EQ so it sounds good, don't worry about 'flat' just use your ears
    sgosden said:
    Helix is sat at home waiting for me. Today has been a loooooong day at work.
    Q. is anyone using a matrix power amp (or similar) to run into stereo cabs?
    Does something like this have a flat EQ section, so that you can use an amp model (pre and power) in the helix without adding an additional power amp characteristic ?
    I run 3 configurations
    1. 2 freyettes going into 2 1x12s, XLRs FOH
    2. Marshall 9100 Stereo Poweramp into 2 1x12s, XLRs into FOH
    3. Direct into FOH and monitors via normal methods
    no need for flat EQ, just twiddle to taste
    worth mentioning I take a path before the cab emulation for 1/4 outs so the cabs are just on the XLRs
  • robinbowesrobinbowes Frets: 3048
    Cabicular said:
    L2 sounds great but pricey
    L2?
    R.
  • TimmyOTimmyO Frets: 7487
    L2?
    R.
    Line6 Stagesource L2t (or L2m)
    Red ones are better.
  • sgosdensgosden Frets: 1994
    with that (mostly no.2) do you tend to run just the pre amp block or the whole amp?
    I feel I have a lot of tweaking ahead of me...
    Whole amthe preamp only is a bit too raw sounding for me
    TimmyO said:
    L2?
    R.
    Thanks.
    If I were to get a Helix (I'm saving up!) I'd want a monitor with a couple of balanced line inputs - one for the output of the helix, and one from the main PA monitoring. I wouldn't want two monitors in front of me.
    I'll look into it more as and when I am in a position to try a Helix.
    R.
    You can do that with an L2 by using the digital out
    although I'm not sure why you wouldn't just monitor the Helix via the desk
  • SporkySporky Frets: 28469
    You could get the Helix to do the mixing...
    Ah, OK, so there are a few ways to do this.
    Excellent.
    R.
    I'm pretty sure you could use a TRS-TS adapter and take the PA send in to Helix and then mix it with your guitar sound and have one output to your monitor, if needed
    Clever
    Or the Xlr
    An interesting utility patch
    http://uk.line6.com/customtone/tone/2301807/
    My expression pedal has developed a loud squeak :-/
  • Give a man a fire and he's warm for the day. But set fire to him and he's warm for the rest of his life
    Silicon spray
  • UnclePsychosisUnclePsychosis Frets: 12923
    TimmyO said:
    An interesting utility patch :
    That's a really cool idea. If it works (and I think it should probably be pretty close) then it would certainly be of great use to a lot of people.
    I gigged the Helix again without a backline amp again last night
    its the way forward
    it sounded amazing
    its the way forward
    it sounded amazing
    It is the way forward, I carry less to gigs, the singer can hear himself and I sound fantastic, even though I do say so myself! :)
