Delay pedal with volume boost?
BidleyBidley Frets: 2938
Which delay pedals give a volume boost when you kick it on? I know of the Tech 21 Boost DLA, which looks awesome, but what else is out there? I'm looking for something that isn't massive, so Boss DD-20s, Memory Men etc need not apply.
  • BidleyBidley Frets: 2938
    edited January 2014
    And typically, as soon as I post this, I find this - looks ideal!
    http://eshop.amtelectronics.com/effect-pedals-fx/amt-electronics-sy-1-stutterfly-digital-delay.html
  • EricTheWearyEricTheWeary Frets: 16303
    One of the Catalinbread ones, I forget. Tech 21 stuff is often cheaper on Thomann so worth a shop around.
    which I can't find on the Catalinbread site. Doh. :(
  • monquixotemonquixote Frets: 17702
    Bluebird but it's expensive
  • gusman2xgusman2x Frets: 922
    The Earthquaker Devices Distaster Transport does. 22dB I believe.
  • Strymon El Capistan does between +/- 3db when you kick it in.
  • hotpickupshotpickups Frets: 1822
    Does it never knew that? I have one. How do you set that up then?
  • crunchmancrunchman Frets: 11480
    Timeline does this as well.
    On the Timeline its a parameter you set on a patch.  You press and hold one of the buttons and you can scroll through a whole bunch of parameters you can tweak - the volume boost being one of them.
  • menamestommenamestom Frets: 4730
    The Zoom zoom ms-70cdr probably does, if it's like the G3.  The individual effect can be boosted or the global level.
  • GassageGassage Frets: 30986
    Providence Chrono also does it.
    The best at it is the SIB Echodrive......if you've a spare grand for an original....
  • thisisguitarthisisguitar Frets: 1073
    edited January 2014
    It's a secondary function on the knobs… whilst holding both footswitches down and all the knobs operate other characteristics. In this case it's the 'Mix' one.
    Have you never tried these?! Because if you haven't I'd suggest doing it with the 'Time' knob first… the spring reverb is most impressive. You've basically been enjoying half a pedal!
    It's a secondary function on the knobs… hold both footswitches down and all the knobs operate other characteristics. In this case it's the 'Mix' one.
    LOL yes but haven't noticed the boost function before :) Thanks
    Phew… I was worried for a moment there! lol. It's such a tweak-able pedal, I love mine.
  • mike257mike257 Frets: 374
    Sounds like you've got a solution, but I'll chime in anyway that the Deluxe Memory Boy will do this for you.  There's a 'Gain' knob which serves to offset any loss of signal level from leaning too far to the wet side of the 'Blend' control but can also put a decent amount of boost into your signal too.
    My favourite sounding delay that is. Absolutely awesome, if I didn't use longer times and need versatility, I'd have one.
