After last week's "Take an open chord (G 320003) and slide it up two frets with a picky arpeggio (Aadd4 540xxx)" from Bryan Adams' Run To You we have the three fret version this week!
"To Begin Again" by Walter Trout starts with A(m)add9 x02200 played as a picked arpeggio for two bars with the picking pattern of strings 5, 4, 3, 2, 1, 2, 3, 4 repeated. He then simply shifts the fretted notes up three frets and plays xx5500 with the same picking pattern; except he stays silent where he was picking the 5th string on the first beat of the bar, while the band play a low F which would be at 1xxxxx.
I can play the whole chord 1x5500 on my short-scale guitar if I'm sitting down with the neck raised to ear-level, so that's the version I'll notate -
Fmaj9#11(no3rd): (1)x5500
The notes are:
a root note F 1xxxxx
a 9th G xx5xxx
a 5th C xxx5xx
a #11th B xxxx0x
a maj7th E xxxxx0
As with last week's chord, "sliding an open chord up and picking an arpeggio" creates an ear-catching semitone clash between the notes on adjacent strings. However, whereas last week's chord 540xxx had an ascending semitone clash between strings 5 and 4, in this week's chord the semitone clash is descending, between the C at xxx5xx and the B at xxxx0x.
So while the picking pattern ascends up the strings (= travels physically downwards towards the floor! :-0 ) the individual notes descend by a semitone down the scale! 8-)
You can see the chord played at 0:14 in this video -
http://www.thefretboard.co.uk/discussion/598/chord-of-the-week-index
