Does anybody know iff this is normal..(valves)
BarneyBarney Frets: 616
edited March 2017 in Amps
I just turned my amp around to measure it for a cover and noticed the valves...is this normal...they look as though they are over heating or something
  • digitalscreamdigitalscream Frets: 26644
    Need a bigger photo, dude - the reflections make it pretty hard to tell at that size.
    <space for hire>
  • BarneyBarney Frets: 616
    Ok ...thanks will take one out and post again... :)
    Ok ...this is a better pic i think :)
  • martinwmartinw Frets: 2149
    If you mean the silvering on the inside of the glass, that is perfectly normal. Part of the manufacturing process.
    It's a pump!  ;)
    It's a pump!  ;)
    Ahhh...yeah thats what i was meaning ... thanks .. i will give myself a slap now  :)
  • KalimnaKalimna Frets: 1540
    Am i correct in thinking that the silvering is from the 'getter' which is a chemical reaction to remove as much 'air' as possible once the manufacture of the valve structure is complete?
    Adam
    Adam
    Yes. Not air though as you imply. Actually Oxygen I think.
  • ICBMICBM Frets: 72457
    Yes - and they deliberately put in too much so the remainder will mop up any tiny amount of air that leaks in over the course of the valve's life. If you see the getter flash becoming thin/semi-transparent or a sort of dirty pink colour, it's more or less used up and the valve doesn't have long left even if it seems to be working OK at the moment.
  • jpfampsjpfamps Frets: 2734
    It usually barium, which reacts with both oxygen and nitrogen to help maintain the vacuum in the valve.
    Cheers for the extra info. I had used the word 'air' as i made the assumption that the valve manufacturing plants did not have de-nitrogenation. I just wasnt sure what would mop up both oxygen and nitrogen.
    Cheers,
    Adam
    Cheers,
    Adam
    It also mops up gas released from the internal structures, for example mica used for spacers has a significant water content.
    This is why valves overheating is bad as it can cause release of gas from internal structures.
    The valve elements are "sparged" with hydrogen before assembly to reduce adsorbed gas too.
  • John_AJohn_A Frets: 3775
    Well that's a new word I've learnt today :)
    Again, very interesting, thank you.
    I know of sparging from the glorious process of beer making, but not this usage.
    Cheers,
    Adam
    You guys talk about stuff sometimes that is so far above my head that it could see the curvature of the earth (er, or not)
    Ok I'll lol that :)
    Cabicular said:
    Ok I'll lol that :)
    I'm genuinely amazed by the knowledge of some folks on here sometimes..! (joking aside, that is)
