Don't forget the string angle at the saddle changes when you fret it (albeit minutely)
http://i.ebayimg.com/images/g/BS8AAOSwMNxXZnQA/s-l1600.jpg
Correct size files and care to keep the slot angled right and remove any burrs, and smooth the slot to remove file marks and maybe a little lube like Nut sauce
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Of course it's really a lot better to not go too far in the first place! Although mistakes do happen even with a lot of experience...
https://1drv.ms/i/s!AryLpsKXwOkHhq5dAmTcVUekduwoVw
https://1drv.ms/i/s!AryLpsKXwOkHhq5f_PCXKhcN5aqsLw
https://1drv.ms/i/s!AryLpsKXwOkHhq5kmpOzV3eGBhYovQ
https://1drv.ms/i/s!AryLpsKXwOkHhq5lQ4_IRXxNPKfaSw
https://1drv.ms/i/s!AryLpsKXwOkHhq5jTtqXx-au5orzYw
https://1drv.ms/i/s!AryLpsKXwOkHhq5mHcLgktBycX93ag
https://1drv.ms/i/s!AryLpsKXwOkHhq5ZOsSYYnXusXuK3g
Now this is my Yamaha.
https://1drv.ms/i/s!AryLpsKXwOkHhq5hKS2r6sDB6sCzxw
https://1drv.ms/i/s!AryLpsKXwOkHhq5eVsb6YrPIEWS3dQ
I read this and it would seem its a good idea to have the strings a little proud of the nut, is that the case or is that more for acoustic guitars?
http://www.lutherie.net/nuts.html
Cunning. You do a dodgy job on the nut to distract the customer so he doesn't notice you've swapped the pickups for terrible cheap ones.
Seriously, though, have you discussed this with the tech that did it? You should at least give him the chance to respond, even if you've decided you don't want him to rectify.
What kind of work will a new pre cut nut need? I can borrow a set of files. Unfortunately the tech I know and trust lives in the far side of London so it might be that Ill be doing this myself. At least if I fluff it up I have only myself to blame. I'm aware that the angle from nut to tuning peg is an issue, anyone want to talk me through it?
