Cable snake for 4CM
djspecialistdjspecialist Frets: 908
Does anybody use a cable snake between pedalboard and amp for 4 cable method?  It seems appealing from the PoV of quicker setup / teardown time, plus reducing the number of trip hazards on the stage.
If so, where can I get one?  Until recently my default port of call would have been KaBL; now that Rob has shut up shop, where should I look?
Trading feedback | FS: Nothing right now
JM build | Pedalboard plans
  • GassageGassage Frets: 30929
    Pete Cornish will make you one and isn't as expensive as you may think
  • UnclePsychosisUnclePsychosis Frets: 12923
    Rob said he would still do orders for people on request - just ask him if he'll do it.
    Also, @CustomPedalBoards may be persuaded.
  • for all things pedal boards please visit www.custompedalboards.co.uk
  • TimmyOTimmyO Frets: 7490
    I used to just get together the cables I was using for it, and every so far down the length use velcro cable wraps. Achieved a similar thing without significant additional cost and I could easily retrieve individual cables should I want to use them for something else.
    Red ones are better.
  • EricTheWearyEricTheWeary Frets: 16298
    The Edge had to move to America to get one , St Patrick having driven  all the cable snakes out of Ireland.
    Happy day after St Paddy's Day everyone :smile:
    That does appeal to the cheapskate in me - but how flexible is the resulting bundle?  I have a feeling it might get all kinked up - did yours ever do that?
    In any case I only have one decent cable of the length I want - so I'd need to buy at least two more for the DIY solution.  (I don't need a footswitch - at least not for my current amp).
    Also, I notice that the CPB loom has right-angled jacks at the board end.  Having winced as people plodded around near the straight jacks sticking out of the back of my board during soundchecks, that suddenly seems like a really good design choice.
    And he still hasn't found what he's looking for
    Depends on the cables and how tortuously you need to route them. If it splays anywhere, add a velcro tie :-)
    I used to do it with my PA insert cables and whatnot too
  • english_bobenglish_bob Frets: 5160
    edited March 2017
    You can get that expanding braided cable sleeving stuff very cheaply. I would have thought that the resulting cable would be more reliable and more easily repairable than a custom made one. Not to mention considerably cheaper.
  • professorbenprofessorben Frets: 5105
    This is what I has got innit.
    My snake is as follows.
    1x midi
    2x switch cables
    1x trs exp controller
    1x guitar signal cable
    combination of cable ties and Velcro straps.
    Colour coded on the ends to corresponding jacks on my pedalboard/controller.
    set up time is minimal as it's all plugged in to the back of my rack setup permanently, so all I have to do is plug in the power, speaker cable and pedalboard.
    Takes about 30s
    In fairness to him it's not easy to navigate where the streets have no name.
  • vizviz Frets: 10705
    Not you too!
    Not you too!
    Don't The Electric Co make them?
    1x midi
    2x switch cables
    Takes about 30s
    Thanks for the Trip Through Your Wires.
  • normula1normula1 Frets: 640
    this is a cheap and cheerful option. http://www.ebay.co.uk/sch/sis.html?_nkw=Spiral+Cable+Wrap%2FTidy%2FHide%2FBanding%2FLoom+~+PC%2CTV%2CHome+Cinema%2CWire+Management&_id=160956288816&&_trksid=p2057872.m2749.l2658
    Go for larger that you think you'll need otherwise the bundle becomes too stiff.
  • BeexterBeexter Frets: 599
    viz said:by
    Not you too!
    Some people have no Pride......
    Beexter said:
    viz said:by
    Not you too!
    This means........ War!
    Not you too!
    Nice of you to notice.
    Really..... it's the sweetest thing.
