Which Guv'nor?
zepp76zepp76 Frets: 2534
edited March 2017 in FX
After reading that Gary Moore used a Marshall Guv'nor along with a JTM45 on the still got the blues album I thought I'd like a piece of that! So, which Guv'nor to go for? A MK1 U.K made one or Korean built? Or the later MK2+? What are the pro's and cons to each one and what price would I be looking at for a good one? Your help is as always greatly appreciated.
Tomorrow will be a good day.
  • mike_lmike_l Frets: 5700
    Get a Mk1. Either will sound great.
    Don't forget that GM's sound came from a cranked and boosted (with the Guv) Marshall  at high volume, sitting at home/in a quiet rehearsal room won't sound exactly like him.
  • I had a Guv'nor MkII for years and absolutely loved it. Was my main OD/Distortion though, wasn't boosting anything. Wow, them were the days! The simpler life!
  • ICBMICBM Frets: 72418
    The MkI is better with an overdriven amp - up to cranked vintage Marshall levels, maybe up to 2203 - the MkII is better as a full-on 'Marshall in a box' into a clean amp.
    There's no circuit difference between the UK and Korean MkIs, although from memory there is a small difference in the components - not sure I would describe it as a 'quality' difference but they're not quite identical-looking. They sound the same, within the variation of normal component tolerances.
  • I've said it before but I prefer the Mk1 by a mile, however it always comes down to your own ears.  What I will say about them though:
    The mk1's are getting old now and can be a bit crackly or noisy, so if can try one before purchase I would recommend it.
    The mk2 has the usual problem of not being able to see where the knobs are set when you're more than 50cm away from it.
  • zepp76zepp76 Frets: 2534
    Thankyou for your input chaps, I think a MK1 may just be on the horizon. It's funny, I said I was getting a JTM45 to play purely without pedals and I'm already looking for a second pedal and I haven't even got the bloomin amp yet!
    I've had 2 Mk 1's at the same time - a UK and a Korean - they side by side sounded identical. So don't fuss if you are looking for one. Its just folks think the Korean is inferior...but the truth is it isn't.
    Mk 2 - (still got), good pedal, far more powerful EQ but a different sounding pedal...still great though! Just differenter.
    Gary used a mark 1.
  • UnclePsychosisUnclePsychosis Frets: 12907
  • ^   This thread is about a Marshall Guv'nor, not a Way Huge Swollen Pickle.
  • TimmyOTimmyO Frets: 7459
    I just saw a UK MkI in the classifieds.
    I have a Korean MkI - it's great. I think I saw an A/B demo video of UK/Korean on Youtube which seemed to prove no audible difference.
    Red ones are better.
  • monquixotemonquixote Frets: 17637
    edited March 2017 tFB Trader
    Another option is that lots of pedals are based on the guvnor like the crunch box.
    Yeah but the Guvnor looks cool :-)
    That's true but most are a bit rattly these days and they are getting expensive.
  • newi123newi123 Frets: 863
    edited March 2017
    I agree with ICBM
    Had a couple of Mk1s - great giving a kick to an already crunchy amp - used mine with a JCM900 and a Peavey 5150 combo (Clean channel run fairly crunchy)
    Used a MK2 into a clean JTM60 and that also sounded fab as a MIAB
    Didn`t like the MK1 running into a clean amp at all.
