I've got a loopmaster channel switcher (with LED!) but it also has an effects loop built in so as well as changing channels, you can engage an effect pedal at the same time. So for example, you can be playing clean one minute, press the switch to change to your lead channel and your delay automatically engages at the same time. Go back to clean and your delay turns off too - no tap dancing.
You don't have to use the effect loop, it just becomes a channel switcher if you don't. Equally, you don't have to use the channel switcher bit, you can just use it as a true bypass looper. Super flexible little pedal. Recent AX8 purchase means I dont need it anymore.
Here's the For Sale thread:
http://www.thefretboard.co.uk/discussion/97553/fs-loopmaster-bypass-looper-amp-channel-switcher-with-effects-loop-very-versatile-switcher-36#latest
